ArcGIS.Desktop.Mapping Namespace / IMapFactory Interface / CreateMapFromJson Method
JSON string containing the map definition.
    CreateMapFromJson Method (IMapFactory)
    Creates a new Map in the project. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Function CreateMapFromJson( _
       ByVal json As String _
    ) As Map
    Map CreateMapFromJson(
       string json
    Parameters
    json
    Return Value
    A map.
    Exceptions
    ExceptionDescription
    JSON string can't be empty.
    Cannot create map with provided JSON string.
    Remarks
    Use this method with a JSON string representing the contents of a mapX file (see Map.SaveAsFile. A web map JSON string such as that created via Map.SaveAsWebMapFile is not valid and will throw an ArgumentException.
    Requirements
