ArcGIS.Desktop.Mapping.Voxel Namespace / SliceDefinition Class / Layer Property
Example
    Layer Property (SliceDefinition)
    Gets the voxel layer with which the slice is associated.
    Syntax
    public VoxelLayer Layer {get;}
    Public ReadOnly Property Layer As VoxelLayer
    Example
    Get Voxel Layer for the Selected Slice in TOC
      var mapView = MapView.Active;
      await QueuedTask.Run(() =>
        voxelLayer = null;
        var slice = mapView?.GetSelectedSlices()?.FirstOrDefault();
        if (slice != null)
          voxelLayer = slice.Layer;
          //TODO - use the layer
    Requirements
