ArcGIS.Core.CIM Namespace / CIMChartDimensionalProfileLandTrendrArguments Class
Properties Methods Events
    CIMChartDimensionalProfileLandTrendrArguments Class Members
    The following tables list the members exposed by CIMChartDimensionalProfileLandTrendrArguments.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the best model proportion value.
    Public Property Gets or sets the maximum number of segments to be fitted to the time series for each pixel.
    Public Property Gets or sets the minimum number of valid observations required to perform fitting.
    Public Property Gets or sets a value indicating whether other bands will be included in the segmentation process.
    Public Property Gets or sets a value indicating whether segments that exhibit a one year recovery will be excluded.
    Public Property Gets or sets the p-value threshold for a model to be selected.
    Public Property Gets or sets a value indicating whether the recovery has an increasing (positive) trend.
    Public Property Gets or sets the recovery threshold value in years.
    Public Property Gets or sets the date in the format MM-DD used to select a slice for each year.
    Public Property Gets or sets the threshold to use for dampening spikes or anomalies in the pixel value trajectory.
    Public Property Gets or sets the number of additional vertices beyond MaximumSegments + 1 that can be used to fit the model during the initial stage of identifying vertices.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMChartDimensionalProfileLandTrendrArguments.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMChartDimensionalProfileLandTrendrArguments with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMChartDimensionalProfileLandTrendrArguments and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
