ArcGIS.Desktop.Mapping Namespace / ElevationSurfaceLayer Class / SetName Method
    SetName Method (ElevationSurfaceLayer)
    Sets the display name for the Elevation Surface Layer. The Ground elevation surface layer cannot be renamed; This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overrides NotOverridable Sub SetName( _
       ByVal newName As String _
    public override void SetName(
       string newName
    Parameters
    newName
    Exceptions
    ExceptionDescription
    Requirements
