ArcGIS.Core.Geometry Namespace / GeometryEngine Class / Intersection Method / Intersection(Geometry,Geometry) Method
The first geometry.
The second geometry.
Example
    Constructs the set-theoretic intersection between two geometries.
    Syntax
    Public Overloads Function Intersection( _
       ByVal geometry1 As Geometry, _
       ByVal geometry2 As Geometry _
    ) As Geometry
    public Geometry Intersection(
       Geometry geometry1,
       Geometry geometry2
    Parameters
    geometry1
    The first geometry.
    geometry2
    Return Value
    A geometry that represents the intersection of the two input geometries. The dimension of the returned geometry will be the lowest dimension of the input geometries. For example, if geometry1 is a MapPoint and geometry2 is a Polyline, the returned geometry will be a MapPoint. If both input geometries are envelopes, then an envelope will be returned. If one input geometry is an envelope and the other is a polygon, then a polygon will be returned. If the dimension of the intersection is not equal to the lowest dimension of the input geometries, an empty geometry will be returned. For example, suppose that geometry1 is a Polyline and geometry2 is a Polyline, and they cross each other at two points. The intersection is a Multipoint, but an empty Polyline will be returned. In this case, if you want the returned geometry to be the Multipoint where the input geometries intersect, use Intersection(Geometry,Geometry,GeometryDimensionType).
    Exceptions
    ExceptionDescription
    Either geometry1 or geometry2 or both are null.
    The method is not implemented for GeometryBag.
    Incompatible spatial references between the input geometries.
    Remarks
    If an input geometry is a Multipatch, then the Multipatch footprint will be used to determine the intersection.
    GeometryEngine Intersection
    Example
    Intersection between two Polylines
      // determine intersection between two polylines
      List<MapPoint> pts =
        MapPointBuilderEx.CreateMapPoint(1.0, 1.0),
      MapPointBuilderEx.CreateMapPoint(3.0, 3.0),
      MapPointBuilderEx.CreateMapPoint(5.0, 1.0),
      Polyline line1 = PolylineBuilderEx.CreatePolyline(pts);
      List<MapPoint> pts2 =
        MapPointBuilderEx.CreateMapPoint(1.0, 3.0),
      MapPointBuilderEx.CreateMapPoint(3.0, 1.0),
      MapPointBuilderEx.CreateMapPoint(5.0, 3.0),
      Polyline line2 = PolylineBuilderEx.CreatePolyline(pts2);
      bool intersects = GeometryEngine.Instance.Intersects(line1, line2);    // intersects = true
      Geometry g = GeometryEngine.Instance.Intersection(line1, line2, GeometryDimensionType.EsriGeometry0Dimension);
      Multipoint resultMultipoint = g as Multipoint;
      // result is a multiPoint that intersects at (2,2) and (4,2)
    Intersection between two Polygons
      // determine intersection between two polygons
      Envelope env1 = EnvelopeBuilderEx.CreateEnvelope(new Coordinate2D(3.0, 2.0), new Coordinate2D(6.0, 6.0));
      Polygon poly1 = PolygonBuilderEx.CreatePolygon(env1);
      Envelope env2 = EnvelopeBuilderEx.CreateEnvelope(new Coordinate2D(1.0, 1.0), new Coordinate2D(4.0, 4.0));
      Polygon poly2 = PolygonBuilderEx.CreatePolygon(env2);
      Polygon polyResult = GeometryEngine.Instance.Intersection(poly1, poly2) as Polygon;
    Requirements
