ArcGIS.Desktop.Catalog Namespace / OpenItemDialog Class / ShowDialog Method
Example
    ShowDialog Method (OpenItemDialog)
    Displays the Browse dialog box to open or use selcted items.
    Syntax
    public override Nullable<bool> ShowDialog()
    Public Overrides NotOverridable Function ShowDialog() As Nullable(Of Boolean)
    Return Value
    A boolean indicating if the Browse dialog was dismissed by pressing OK or Cancel.
    Remarks
    You can either configure the Browse dialog box properties first then display it with the ShowDialog method, or display the dialog box and then set its properties.
    Example
    Show OpenItemDialog
      OpenItemDialog addToProjectDialog = new()
        Title = "Add To Project",
        InitialLocation = @"C:\Data\NewYork\Counties\Maps",
        MultiSelect = true,
        Filter = ItemFilters.Composite_Maps_Import
      bool? ok = addToProjectDialog.ShowDialog();
      if (ok == true)
        IEnumerable<Item> selectedItems = addToProjectDialog.Items;
        foreach (Item selectedItem in selectedItems)
          MapFactory.Instance.CreateMapFromItem(selectedItem);
    BrowseDialogItems
        MultiSelect = true,
      if (ok == true)
        IEnumerable<Item> selectedDialogItems = addToProjectDialog.Items;
        foreach (Item selectedDialogItem in selectedDialogItems)
          MapFactory.Instance.CreateMapFromItem(selectedDialogItem);
    Geodatabase Content from Browse Dialog
      var openDlg = new OpenItemDialog
        Title = "Select a Feature Class",
        InitialLocation = @"C:\Data",
        MultiSelect = false,
        BrowseFilter = BrowseProjectFilter.GetFilter(ItemFilters.GeodatabaseItems_All)
      //show the browse dialog
      bool? ok = openDlg.ShowDialog();
      if (!ok.HasValue || openDlg.Items.Count == 0)
        // nothing selected, leave
      var mapView = MapView.Active;
      await QueuedTask.Run(() =>
        // get the item
        var item = openDlg.Items.First();
        // see if the item has a dataset
        if (ItemFactory.Instance.CanGetDataset(item))
          // get it
          using var ds = ItemFactory.Instance.GetDataset(item);
          // access some properties
          var name = ds.GetName();
          var path = ds.GetPath();
          // if it's a featureclass
          if (ds is FeatureClass fc)
            // create a layer
            var featureLayerParams = new FeatureLayerCreationParams(fc)
              MapMemberIndex = 0
            var layer = LayerFactory.Instance.CreateLayer<FeatureLayer>(featureLayerParams, mapView.Map);
            // continue
    Workflow to open an ArcGIS Pro project using the OpenItemDialog
      BrowseProjectFilter portalAndLocalProjectsFilter = new();
      //A filter to pick projects from the portal
      //This filter will allow selection of ppkx and portal project items on the portal
      portalAndLocalProjectsFilter.AddFilter(BrowseProjectFilter.GetFilter("esri_browseDialogFilters_projects_online_proprojects"));
      //A filter to pick projects from the local machine
      portalAndLocalProjectsFilter.AddFilter(BrowseProjectFilter.GetFilter("esri_browseDialogFilters_projects"));
      //Create the OpenItemDialog and set the filter to the one we just created
      var openDlg = new OpenItemDialog()
        Title = "Select a Project",
        BrowseFilter = portalAndLocalProjectsFilter
      //Show the dialog
      var result = openDlg.ShowDialog();
      //Check if the user clicked OK and selected an item
        return; //nothing selected
      var selectedItem = openDlg.Items.FirstOrDefault();
      //Open the project use the OpenAsync method.
    Requirements
