ArcGIS.Desktop.Core Namespace / CoreModule Class
Members Example
    CoreModule Class
    Represents the core module, which provides access to the current project
    Object Model
    CoreModule ClassProject Class
    Syntax
    Example
    Suggested command options in CommandSearch when a tab is activated.
      //In the module class..
      //Return the static list of daml ids you want to be the (suggested)
      //defaults relevant to the given tab. It can be none, some, or all of the
      //commands associated with the activeTabID.
      //In this example, there are two tabs. This example arbitrarily
      //identifies just one command on each tab to be a default to show in the
      //command search list (when _that_ particular tab is active)
      switch (activeTabID)
        case "CommandSearch_Example_Tab1":
          result = ["CommandSearch_Example_Button2"];
          break;
        case "CommandSearch_Example_Tab2":
          result = ["CommandSearch_Example_Button4"];
          break;
      result = [""]; // Default case
    Inheritance Hierarchy
    Requirements
