| Name | Description | |
![]() | OneDriveFileStatusDockPaneId |
The following tables list the members exposed by CoreModule.
![]() | Caption | Gets the name of the Module. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() ![]() | CurrentProject | Gets the project that is currently open in the ArcGIS Pro application |
![]() | ShowAdvancedItemPopups | Controls whether pop-ups appear in the Catalog pane and views with or without details. |
![]() | ShowItemPopups | Controls whether pop-ups appear in the Catalog pane and views. |
![]() | ID | Gets the DAML identifier. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | GetSuggestedCMDIDs | Overridden. Gets the suggested daml ids for the given tab identified by 'activeTabID' |
![]() | RepathProjectItem | Repath the item's catalog path to the path provided |
![]() | RepathProjectItemAsync | Repath the item's catalog path to the path provided asynchronously |
![]() | CanCopyAsync | Modules are constantly polled giving them the opportunity to enable the application's Copy button. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | CanCutAsync | Modules are constantly polled giving them the opportunity to enable the application's Cut button. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | CanDeleteAsync | Modules are constantly polled giving them the opportunity to enable the application's Delete button. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | CanDuplicateAsync | Modules are constantly polled giving them the opportunity to enable the application's Duplicate button. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | CanPasteAsync | Modules are constantly polled giving them the opportunity to enable the application's Paste button. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | CanPasteSpecialAsync | Modules are constantly polled giving them the opportunity to enable the application's PasteSpecial button. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | CanUnload | When overridden in a derived class, a Module can return that it can't be unloaded. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | CopyAsync | Called when the Copy command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | CutAsync | Called when the Cut command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | DeleteAsync | Called when the Delete command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | DuplicateAsync | Called when the Duplicate command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | ExecuteCommand | Override this method to allow users to execute DAML commands specified in this module. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | ExecuteCommandArgs | Override this method to allow users to execute DAML commands specified in this module. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | NotifyPropertyChanged | Overloaded. (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase) |
![]() | OnPaneActivated | Called by the Framework when a Pane is activated. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | OnPaneClosed | Called by the Framework when a Pane is closed. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | OnPaneClosing | Called by the Framework when one of the Module's Pane is about to close. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | OnPaneDeactivated | Called by the Framework when a Pane is deactivated. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | OnPaneOpened | Called by the Framework when a new Pane is opened. This occurs after the pane has been fully initialized. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | OnReadSettingsAsync | Override this method to read custom settings written to the current project. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | OnWriteSettingsAsync | Override this method to write custom settings to the current project when it is saved. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | PasteAsync | Called when the Paste command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | PasteSpecialAsync | Called when the PasteSpecial command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module) |
![]() | SetProperty | Overloaded. (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase) |
![]() | PropertyChanged | Occurs when a property value changes. (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase) |
