ArcGIS.Desktop.Core Namespace / Project Class / OpenAsync Method
The full path or URL to the project or project package that will be opened
Example
    OpenAsync Method (Project)
    Opens an existing project or project package
    Syntax
    public static Task<Project> OpenAsync(
       string projectUri
    Public Shared Function OpenAsync( _
       ByVal projectUri As String _
    ) As Task(Of Project)
    Parameters
    projectUri
    Return Value
    A Task returning the project that was opened
    Exceptions
    ExceptionDescription
    Project open exception base class
    User is not logged in
    Remarks
    ArcGIS Pro can open projects or project packages stored on a local or network computer, portal projects available from an ArcGIS Enterprise portal, and project packages available from an ArcGIS Enterprise portal or ArcGIS Online. Provide a valid file path or URL as appropriate. When a URL is provided, the portal associated with the URL must be the active portal, and you must sign in to the organization unless you are accessing a public project package.
    A local cache of the portal project is created in the download location specified by the GeneralOptions settings, then a project file (*.aprx) representing the portal project is opened by ArcGIS Pro.
    Alternatively, a project package stored in a portal is downloaded from the portal as determined by the DownloadOptions settings. All project packages are unpacked, then the project file (*.aprx) provided by the package is opened by ArcGIS Pro.
    If a project is currently open in ArcGIS Pro, it will be closed before the specified project is opened.
    Example
    Workflow to open an ArcGIS Pro project
      projectPath = @"https://<userName>.<domain>.com/portal/sharing/rest/content/items/1a434faebbe7424d9982f57d00223baa";
      string docVer = string.Empty;
      // A portal project path looks like this:
      //@"https://<ServerName>.<Domain>.com/portal/sharing/rest/content/items/1a434faebbe7424d9982f57d00223baa";
      //A local project path looks like this:
      //@"C:\Users\<UserName>\Documents\ArcGIS\Projects\MyProject\MyProject.aprx";
      //Check if the project can be opened
      if (Project.CanOpen(projectPath, out docVer))
        //Open the project
        Project.OpenAsync(projectPath);
      else //The project cannot be opened
        //One possible reason: If the project is a portal project, the active portal must match the portal of the project
        //Check if this is a portal project
        bool isPortalProject = Uri.TryCreate(projectPath, UriKind.Absolute, out Uri uriResult)
             && (uriResult.Scheme == Uri.UriSchemeHttp || uriResult.Scheme == Uri.UriSchemeHttps);
        if (isPortalProject)
          //Parse the project path to get the portal
          var uri = new Uri(projectPath);
          var portalUrlOfProjectToOpen = $"{uri.Scheme}://{uri.Host}/portal/";
          //Get the current active portal
          var activePortal = ArcGISPortalManager.Current.GetActivePortal();
          //Compare to see if the active Portal is the same as the portal of the project
          bool isSamePortal = activePortal != null && activePortal.PortalUri.ToString() == portalUrlOfProjectToOpen;
          if (!isSamePortal) //not the same.
            //Set new active portal to be the portal of the project
            //Find the portal to sign in with using its Uri...
            var projectPortal = ArcGISPortalManager.Current.GetPortal(new Uri(portalUrlOfProjectToOpen, UriKind.Absolute));
            bool returnAfterSignIn = await QueuedTask.Run(() =>
              if (!projectPortal.IsSignedOn())
                //Calling "SignIn" will trigger the OAuth popup if your credentials are
                //not cached (eg from a previous sign in in the session)
                if (projectPortal.SignIn().success)
                  //Set this portal as my active portal
                  ArcGISPortalManager.Current.SetActivePortal(projectPortal);
                  return true;
              return false;
            if (returnAfterSignIn)
              return;
            //Now try opening the project again
            else
              System.Diagnostics.Debug.WriteLine("The project cannot be opened.");
          else //The portals are the same. So the problem could be something else - permissions, portal is down?
        else //Project is on disk and cannot be opened.
    Retrieve a project item from a portal and open it
      var projectPortal = ArcGISPortalManager.Current.GetPortal(new Uri(@"https://<serverName>.<domain>.com/portal/", UriKind.Absolute));
      string owner = string.Empty;
      //Get the signed on user name
      owner = await QueuedTask.Run(() => projectPortal.GetSignOnUsername());
      //Get the user content from the portal
      PortalUserContent userContent = await projectPortal.GetUserContentAsync(owner);
      //Get the first portal project item
      var firstPortalProject = userContent.PortalItems.FirstOrDefault(pi => pi.PortalItemType == PortalItemType.ProProject);
      var portalProjectUri = firstPortalProject.ItemUri.ToString();
      //Check if project can be opened
      if (Project.CanOpen(portalProjectUri, out docVer))
        Project.OpenAsync(portalProjectUri);
      //Note: If Project.CanOpen returns false, the project cannot be opened. One reason could be
      // the active portal is not the same as the portal of the project. Refer to the snippet: [Workflow to open an ArcGIS Pro project](ProSnippets-sharing#workflow-to-open-an-arcgis-pro-project)
    Open an existing project
      //Opens an existing project or project package
      // example: @"C:\Data\MyProject1\MyProject1.aprx"
      var project = await Project.OpenAsync(projectPath);
      // Use project
    How to access Geoprocessing History
      string openProjectPath = @"D\DATA\IGPHistoryItemTestProject\IGPHistoryItemTestProject.aprx";
      await Project.OpenAsync(openProjectPath);
      MapProjectItem mapProjItem = Project.Current.GetItems<MapProjectItem>().FirstOrDefault(item => item.Name.Equals("Map", StringComparison.CurrentCultureIgnoreCase));
      var ftrLayer = await QueuedTask.Run(() =>
        var map = mapProjItem.GetMap();
        return map.Layers[0] as FeatureLayer;
      string tool1 = "management.GetCount";
      var args1 = Geoprocessing.MakeValueArray(ftrLayer);
      var env = Geoprocessing.MakeEnvironmentArray(overwriteoutput: true);
      GPExecuteToolFlags executeFlags = GPExecuteToolFlags.AddToHistory;
      var t = await Geoprocessing.ExecuteToolAsync(tool1, args1, env, null, null, executeFlags);
      IEnumerable<IGPHistoryItem> hisItems = Project.Current.GetProjectItemContainer(Geoprocessing.HistoryContainerKey) as IEnumerable<IGPHistoryItem>;
      string hitemID = "";
      string hitemToolPath = "";
      IGPResult hitemGPResult = null;
      DateTime hitemTimeStamp;
      foreach (var hitem in hisItems)
        // common IGPHistoryItem and Item properties
        hitemID = (hitem as Item).ID;
        hitemToolPath = hitem.ToolPath;
        hitemGPResult = hitem.GPResult;
        hitemTimeStamp = hitem.TimeStamp;
        // use the properties as needed
    Requirements
