ArcGIS.Desktop.Core.Geoprocessing Namespace / IGPResult Interface
    IGPResult Interface Properties
    For a list of all members of this type, see IGPResult members.
    Public Properties
     NameDescription
     PropertyGeoprocessing environments used locally in tool execution.
    • Tuple.Item1 - name
    • Tuple.Item2 - datatype
    • Tuple.Item3 - value
     PropertyError code for tool execution result:
    • 0 : Success (tool executed without any error)
    • not 0 : Tool failed or was canceled.
     Property Returns error messages - see code example below:
     Property True if tool executed with any warning.
     Property True if tool execution is canceled before it finishes.
     Property True when tool fails or canceled.
     Property All output messages. To filter only one type of messages use GPMessageType (Warning, Error) - see code example below.
     Property
    • Tuple.Item4 - input = true, output = false
     Property Returns execution result value as a string or null if tool execution fails.
     Property Output values, null if tool execution fails.
     Property Data types of output values, null if tool fails.
    Top
