ArcGIS.Desktop.Editing Namespace / EditOperation.IEditContext Interface / Invalidate Method / Invalidate(Row) Method
The feature/row to invalidate.
Example
    Invalidates a feature/row.
    Syntax
    void Invalidate(
       Row row
    Overloads Sub Invalidate( _
       ByVal row As Row _
    Parameters
    row
    Example
    Creating a Row
      await QueuedTask.Run(() =>
        string message = String.Empty;
        bool creationResult = false;
        EditOperation editOperation = new EditOperation();
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
        using (Table enterpriseTable = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.piCIPCost"))
          // Declare the callback here. We are not executing it .yet.
          editOperation.Callback(context =>
            TableDefinition tableDefinition = enterpriseTable.GetDefinition();
            int assetNameIndex = tableDefinition.FindField("ASSETNA");
            using (RowBuffer rowBuffer = enterpriseTable.CreateRowBuffer())
              // Either the field index or the field name can be used in the indexer.
              rowBuffer[assetNameIndex] = "wMain";
              rowBuffer["COST"] = 700;
              rowBuffer["ACTION"] = "Open Cut";
              // subtype value for "Abandon".
              rowBuffer[tableDefinition.GetSubtypeField()] = 3;
              using (Row row = enterpriseTable.CreateRow(rowBuffer))
                // To Indicate that the attribute table has to be updated.
                context.Invalidate(row);
          }, enterpriseTable);
          try
            creationResult = editOperation.Execute();
            if (!creationResult)
              message = editOperation.ErrorMessage;
          catch (GeodatabaseException exObj)
            message = exObj.Message;
        if (!string.IsNullOrEmpty(message))
          Debug.WriteLine(message);
    Modifying a Row
        bool modificationResult = false;
            QueryFilter openCutFilter = new QueryFilter { WhereClause = "ACTION = 'Open Cut'" };
            using (RowCursor rowCursor = enterpriseTable.Search(openCutFilter, false))
              int subtypeFieldIndex = tableDefinition.FindField(tableDefinition.GetSubtypeField());
              while (rowCursor.MoveNext())
                using (Row row = rowCursor.Current)
                  // In order to update the Map and/or the attribute table.
                  // Has to be called before any changes are made to the row.
                  row["ASSETNA"] = "wMainOpenCut";
                  if (Convert.ToDouble(row["COST"]) > 700)
                    // Abandon asset if cost is higher than 700 (if that is what you want to do).
                    row["ACTION"] = "Open Cut Abandon";
                    row[subtypeFieldIndex] = 3; //subtype value for "Abandon"
                  //After all the changes are done, persist it.
                  row.Store();
                  // Has to be called after the store too.
          try
            modificationResult = editOperation.Execute();
            if (!modificationResult)
    Modifying a Feature
        using (FeatureClass enterpriseFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.FacilitySite"))
          FeatureClassDefinition facilitySiteDefinition = enterpriseFeatureClass.GetDefinition();
          int ownTypeIndex = facilitySiteDefinition.FindField("OWNTYPE");
          int areaIndex = facilitySiteDefinition.FindField(facilitySiteDefinition.GetAreaField());
            QueryFilter queryFilter = new QueryFilter
              WhereClause = "FCODE = 'Hazardous Materials Facility' AND OWNTYPE = ' '"
            using (RowCursor rowCursor = enterpriseFeatureClass.Search(queryFilter, false))
                using (Feature feature = (Feature)rowCursor.Current)
                  context.Invalidate(feature);
                  // Transfer all Hazardous Material Facilities to the City.
                  feature[ownTypeIndex] = "Municipal";
                  if (Convert.ToDouble(feature[areaIndex]) > 50000)
                    // Set the Shape of the feature to whatever you need.
                    List<Coordinate2D> newCoordinates = new List<Coordinate2D>
                        new Coordinate2D(1021570, 1880583),
                        new Coordinate2D(1028730, 1880994),
                        new Coordinate2D(1029718, 1875644),
                        new Coordinate2D(1021405, 1875397)
                    feature.SetShape(new PolygonBuilderEx(newCoordinates).ToGeometry());
                  feature.Store();
          }, enterpriseFeatureClass);
          try
    Deleting a Row/Feature
        bool deletionResult = false;
                  // In order to update the Map and/or the attribute table. Has to be called before the delete.
                  row.Delete();
          try
            deletionResult = editOperation.Execute();
            if (!deletionResult)
    Requirements
