ArcGIS.Desktop.Editing Namespace / EditOperation Class / Callback Method / Callback(Action<IEditContext>,Dataset[]) Method
The function object.
The datasets to operate on.
Example
    Registers that the edit operation will callback into the given function in the context of an edit operation. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Sub Callback( _
       ByVal action As Action(Of EditOperation.IEditContext), _
       ByVal ParamArray datasets() As Dataset _
    public void Callback(
       Action<EditOperation.IEditContext> action,
       params Dataset[] datasets
    Parameters
    action
    datasets
    Exceptions
    ExceptionDescription
    Example
    Read and Write blob fields with a row cursor in a callback
    await QueuedTask.Run(() =>
          var editOp = new EditOperation() { Name = "Blob Cursor" };
          var featLayer = activeMap.FindLayers("Hydrant").First() as FeatureLayer;
          editOp.Callback((context) =>
                  using (var rc = featLayer.GetTable().Search(null, false))
                    while (rc.MoveNext())
                      using (var record = rc.Current)
                        //read the blob field and save to a file
                        var msw = new MemoryStream();
                        msw = record["BlobField"] as MemoryStream;
                        using (FileStream file = new(@"d:\temp\blob.jpg", FileMode.Create, FileAccess.Write))
                          msw.WriteTo(file);
                        //read file into memory stream
                        var msr = new MemoryStream();
                        using (FileStream file = new(@"d:\images\Hydrant.jpg", FileMode.Open, FileAccess.Read))
                          file.CopyTo(msr);
                        //put the memory stream in the blob field and save to feature
                        record["BlobField"] = msr;
                        record.Store();
                }, featLayer.GetTable());
          if (!editOp.IsEmpty)
            var result = editOp.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not
    Creating a Row
        string message = String.Empty;
        bool creationResult = false;
        EditOperation editOperation = new EditOperation();
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
        using (Table enterpriseTable = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.piCIPCost"))
          // Declare the callback here. We are not executing it .yet.
          editOperation.Callback(context =>
            TableDefinition tableDefinition = enterpriseTable.GetDefinition();
            int assetNameIndex = tableDefinition.FindField("ASSETNA");
            using (RowBuffer rowBuffer = enterpriseTable.CreateRowBuffer())
              // Either the field index or the field name can be used in the indexer.
              rowBuffer[assetNameIndex] = "wMain";
              rowBuffer["COST"] = 700;
              rowBuffer["ACTION"] = "Open Cut";
              // subtype value for "Abandon".
              rowBuffer[tableDefinition.GetSubtypeField()] = 3;
              using (Row row = enterpriseTable.CreateRow(rowBuffer))
                // To Indicate that the attribute table has to be updated.
                context.Invalidate(row);
          }, enterpriseTable);
          try
            creationResult = editOperation.Execute();
            if (!creationResult) message = editOperation.ErrorMessage;
          catch (GeodatabaseException exObj)
            message = exObj.Message;
        if (!string.IsNullOrEmpty(message))
          Debug.WriteLine(message);
    Requirements
