ArcGIS.Core.CIM Namespace / CIMDefinition Class
Properties Methods Events
    CIMDefinition Class Members
    The following tables list the members exposed by CIMDefinition.
    Public Properties
     NameDescription
    Public Property Gets or sets the metadata URI.
    Public Property Gets or sets the name.
    Public Property Gets or sets the time the source was last modified, as of the last sync. Used to detect when another sync is needed.
    Public Property Gets or sets the source portal URI of the item. Set if sourced from an external item such as an item on a portal.
    Public Property Gets or sets the source URI of the item. Set if sourced from an external item such as an item on a portal.
    Public Property Gets or sets the URI of the definition. Typically set by the system and used as an identifier.
    Public Property Gets or sets a value indicating whether the CIM definition accesses metadata from its data source (the default behavior), or if it has its own metadata stored in the project.
    Top
    Public Methods
     NameDescription
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Creates a JSON encoding of the CIMObject and its current state. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
