Parameters
- member
- mapMember
- oid
- object ID
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
// Creates a new feature by copying and optionally modifying the attributes of an existing feature using an inspector. await QueuedTask.Run(() => { // Create an inspector and load a feature // The inspector is used to modify the attributes of the feature before creating it var insp = new Inspector(); insp.Load(featureLayer, objectId); // modify attributes if necessary // insp["Field1"] = newValue; //Create new feature from an existing inspector (copying the feature) var createOp = new EditOperation() { Name = "Create from insp" }; createOp.Create(insp.MapMember, insp.ToDictionary(a => a.FieldName, a => a.CurrentValue)); if (!createOp.IsEmpty) { var result = createOp.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not } });
// Duplicates a feature in a feature layer and modifies its geometry. await QueuedTask.Run(() => { var duplicateFeatures = new EditOperation() { Name = "Duplicate Features" }; //Duplicate with an X and Y offset of 500 map units //Execute to execute the operation //Must be called within QueuedTask.Run var insp2 = new Inspector(); insp2.Load(featureLayer, objectId); var geom = insp2["SHAPE"] as Geometry; var rtoken = duplicateFeatures.Create(insp2.MapMember, insp2.ToDictionary(a => a.FieldName, a => a.CurrentValue)); if (!duplicateFeatures.IsEmpty) { if (duplicateFeatures.Execute())//Execute and ExecuteAsync will return true if the operation was successful and false if not { var modifyOp = duplicateFeatures.CreateChainedOperation(); modifyOp.Modify(featureLayer, (long)rtoken.ObjectID, GeometryEngine.Instance.Move(geom, 500.0, 500.0)); if (!modifyOp.IsEmpty) { var result = modifyOp.Execute(); } } } });
// Merges multiple features from a source feature layer into a new feature, optionally using a template or inspector, and supports merging into a destination layer. await QueuedTask.Run(() => { var mergeFeatures = new EditOperation() { Name = "Merge Features" }; //Merge three features into a new feature using defaults //defined in the current template mergeFeatures.Merge(currentTemplate as EditingRowTemplate, featureLayer, [10, 96, 12]); //Merge three features into a new feature in the destination layer mergeFeatures.Merge(destinationLayer, featureLayer, [10, 96, 12]); //Use an inspector to set the new attributes of the merged feature var inspector = new Inspector(); inspector.Load(featureLayer, objectId);//base attributes on an existing feature inspector["NAME"] = "New name"; inspector["DESCRIPTION"] = "New description"; //Merge features into a new feature in the same layer using the //defaults set in the inspector mergeFeatures.Merge(featureLayer, [10, 96, 12], inspector); //Execute to execute the operation //Must be called within QueuedTask.Run if (!mergeFeatures.IsEmpty) { //Execute and ExecuteAsync will return true if the operation was successful and false if not var result = mergeFeatures.Execute(); //or use async flavor //await mergeFeatures.ExecuteAsync(); } });
// Modifies a single feature in the specified feature layer. await QueuedTask.Run(() => { var modifyFeature = new EditOperation() { Name = "Modify a feature" }; //use an inspector var modifyInspector = new Inspector(); modifyInspector.Load(featureLayer, objectId);//base attributes on an existing feature //change attributes for the new feature modifyInspector["SHAPE"] = polygon;//Update the geometry modifyInspector["NAME"] = "Updated name";//Update attribute(s) modifyFeature.Modify(modifyInspector); //update geometry and attributes using overload var featureAttributes = new Dictionary<string, object> { ["NAME"] = "Updated name"//Update attribute(s) }; modifyFeature.Modify(featureLayer, objectId, polygon, featureAttributes); //Execute to execute the operation //Must be called within QueuedTask.Run if (!modifyFeature.IsEmpty) { //Execute and ExecuteAsync will return true if the operation was successful and false if not var result = modifyFeature.Execute(); //or use async flavor //await modifyFeatures.ExecuteAsync(); } });
// Updates the text of an annotation feature in the specified annotation layer. await QueuedTask.Run(() => { // annotationLayer is ~your~ Annotation layer... // use the inspector methodology var insp = new Inspector(); insp.Load(annotationLayer, objectId); // get the annotation properties AnnotationProperties annoProperties = insp.GetAnnotationProperties(); // set the attribute annoProperties.TextString = annotationText; // assign the annotation properties back to the inspector insp.SetAnnotationProperties(annoProperties); //create and execute the edit operation EditOperation op = new EditOperation(); op.Name = "Update annotation"; op.Modify(insp); if (!op.IsEmpty) { var result = op.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not } });
// Modifies the geometry of an annotation feature in the specified annotation layer. await QueuedTask.Run(() => { //Don't use 'Shape'....Shape is the bounding box of the annotation text. This is NOT what you want... // //var insp = new Inspector(); //insp.Load(annotationLayer, objectId); //var shape = insp["SHAPE"] as Polygon; //...wrong shape... //Instead, we must use the AnnotationProperties //annotationLayer is ~your~ Annotation layer var insp = new Inspector(); insp.Load(annotationLayer, objectId); AnnotationProperties annoProperties = insp.GetAnnotationProperties(); var shape = annoProperties.Shape; if (shape.GeometryType != GeometryType.GeometryBag) { var newGeometry = GeometryEngine.Instance.Move(shape, 10, 10); annoProperties.Shape = newGeometry; insp.SetAnnotationProperties(annoProperties); EditOperation op = new EditOperation { Name = "Change annotation angle" }; op.Modify(insp); if (!op.IsEmpty) { var result = op.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not } } });
// Modifies the text graphic of a selected annotation feature in the specified annotation layer. await QueuedTask.Run(() => { var selection = annotationLayer.GetSelection(); if (selection.GetCount() == 0) { return; } // use the first selected feature var insp = new Inspector(); insp.Load(annotationLayer, selection.GetObjectIDs().FirstOrDefault()); // getAnnoProperties should return null if not an annotation feature AnnotationProperties annoProperties = insp.GetAnnotationProperties(); // get the textGraphic CIMTextGraphic textGraphic = annoProperties.TextGraphic; // change text textGraphic.Text = "Hello world"; // set x,y offset via the symbol var symbol = textGraphic.Symbol.Symbol; var textSymbol = symbol as CIMTextSymbol; textSymbol.OffsetX = 2; textSymbol.OffsetY = 3; textSymbol.HorizontalAlignment = HorizontalAlignment.Center; // load the updated textGraphic annoProperties.LoadFromTextGraphic(textGraphic); // assign the annotation properties back insp.SetAnnotationProperties(annoProperties); EditOperation op = new EditOperation { Name = "modify symbol" }; op.Modify(insp); if (!op.IsEmpty) { bool result = op.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not } });
var oid = 1;
// See "Change Annotation Text Graphic" for an alternative if TEXTSTRING is missing from the schema
insp.Load(annotationLayer, oid);
// make sure TextString attribute exists.
//It is not guaranteed to be in the schema
ArcGIS.Desktop.Editing.Attributes.Attribute att = insp.FirstOrDefault(a => a.FieldName == "TEXTSTRING");
if (att != null)
insp["TEXTSTRING"] = "Hello World";
op.Modify(insp);
//OR using a Dictionary - again TEXTSTRING has to exist in the schema
//Dictionary<string, object> newAtts = new Dictionary<string, object>();
//newAtts.Add("TEXTSTRING", "hello world");
//op.Modify(annotationLayer, oid, newAtts);
op.Execute();
//must support editing!
if (!featSceneLayer.HasAssociatedFeatureService ||
!featSceneLayer.IsEditable)
return;
var editOp = new EditOperation()
Name = "Edit FeatureSceneLayer Attributes",
SelectModifiedFeatures = true
//make an inspector
//get the attributes for the specified oid
inspector.Load(featSceneLayer, oid);
inspector["PermitNotes"] = "test";//modify
editOp.Modify(inspector);
editOp.Execute();//synchronous flavor
//assume the geometry used in SelectFeaturesEx() is coming from a
//map tool...
//SketchType = SketchGeometryType.Rectangle;
//SketchOutputMode = SketchOutputMode.Screen;
var mapView = MapView.Active;
if (mapView == null)
return;
var result = mapView.SelectFeaturesEx(geometry);
//Get scene layers with selections
var scene_layers = result.ToDictionary<FeatureSceneLayer>();
foreach (var kvp in scene_layers)
var scene_layer = kvp.Key as FeatureSceneLayer;
var sel_oids = kvp.Value;
//If there are attributes then get them
if (scene_layer.HasAssociatedFeatureService)
foreach (var objectid in sel_oids)
insp.Load(scene_layer, objectid);
//TODO something with retrieved attributes
