ArcGIS.Desktop.Editing.Templates Namespace / AttributeDef Class / AttributeDef Constructor / AttributeDef Constructor(String,String,FieldType,Object,Boolean,Boolean)
a unique identifier
a localizable AttributeDef name that may appear in a GUI
the attribute type
the default attribute value if otherwise unspecified
true if the value can be null, false otherwise
true if the value must be in meters, false otherwise
    Creates an AttributeDef
    Syntax
    Public Function New( _
       ByVal id As String, _
       ByVal name As String, _
       ByVal type As FieldType, _
       ByVal defaultValue As Object, _
       ByVal isNullable As Boolean, _
       Optional ByVal unitAsMeters As Boolean _
    Parameters
    id
    a unique identifier
    name
    type
    the attribute type
    defaultValue
    isNullable
    unitAsMeters
    Requirements
