An overview of the Raster Math toolset
Available with 3D Analyst license.
Available with Spatial Analyst license.
Available with Image Analyst license.
The Raster Math tools perform mathematical operations on input rasters.
The arithmetic tools perform addition (Plus), subtraction (Minus), multiplication (Times), and division (Divide) between two inputs. The inputs can be rasters or numbers (as constant value rasters).
The remaining tools apply only to a single input raster and will either convert a floating-point raster to integer (Int) or an integer raster to floating point (Float).
License:
These Math tools are also available if you have a Spatial Analyst or an Image Analyst extension license.
Tool
Divide
Divides the values of two rasters on a cell-by-cell basis.
Float
Converts each cell value of a raster into a floating-point representation.
Int
Converts each cell value of a raster to an integer by truncation.
Minus
Subtracts the value of the second input raster from the value of the first input raster on a cell-by-cell basis.
Plus
Adds (sums) the values of two rasters on a cell-by-cell basis.
Times
Multiplies the values of two rasters on a cell-by-cell basis.
Tools of the Raster Math toolset
A more comprehensive range of mathematical calculations (trigonometric, exponential, logical, and so forth) is available with the ArcGIS Spatial Analyst extension license.
