Polygon Neighbors (Analysis Tools)
Summary
Creates a table with statistics based on polygon contiguity (overlaps, coincident edges, or nodes).
Learn more about how the Polygon Neighbors and Pairwise Polygon Neighbors tools work
Illustration
Polygon Neighbors tool illustration
A diagram of a source polygon and its neighbor polygons is shown.
Usage
  • The tool analyzes polygon contiguity, summarizing the following between source polygons and neighbor polygons:
    • The area of overlaps (overlapping neighbors—optional)
    • The length of coincident edges (edge neighbors)
    • The number of times boundaries cross or touch at a point (node neighbors)
    The summary information is written to an output table. A source polygon may have one or more neighbor polygons; a neighbor polygon is spatially related with the source polygon in at least one of the ways described above.
  • Only first-order contiguity is analyzed and reported by the tool. Relationships beyond that are not examined, that is, neighbors of neighbors (second-order contiguity) are not examined.
  • The Report By Fields parameter is used to identify unique polygons or polygon groups and report their neighboring information by the polygons or polygon groups. To find the neighbors of each individual polygon in the input, specify one or more input fields that result in a unique value or set of values (in the case of multiple fields) for every polygon.
    If the specified fields identify unique polygon groups, the neighboring information is summarized and reported by the groups.
    See How Polygon Neighbors and Pairwise Polygon Neighbors works for details on the use of this parameter.
  • You can use the Include area overlaps parameter to analyze overlapping area relationships. When Include area overlaps is checked, the output table will contain an AREA field that stores the area of overlap for the overlapping neighbor being analyzed. If no overlap is found, the AREA field value is 0.
    Tip:
    Calculating overlapping area relationships is a high-resource operation, and performance may be slower than determining coincident edge and node neighbor relationships. If you know that the data has no overlapping features or you are not interested in analyzing overlapping neighbors, ensure that the Include area overlaps parameter is not checked.
    Caution:
    The Include area overlaps parameter must be checked to obtain records for neighbors that are completely contained by a source polygon. If the Include area overlaps parameter is not checked, the output table will not contain records for neighbors that are completely contained in a source polygon.
  • There is no entry in the output table for features that are not neighbors.
  • The Include both sides of neighbor relationship parameter is used to control the relationships included in the output. To report all contiguity relationships, including reciprocal relationships, check Include both sides of neighbor relationship. For example, if OID1 is a neighbor of OID2, an entry is written to the output table for OID1 having a neighbor OID2 and for OID2 having a neighbor OID1. If you only want the first side of the relationship, uncheck Include both sides of neighbor relationship. Using the example above but with Include both sides of neighbor relationship unchecked, only the entry for OID1 having a neighbor OID2 will be included in the output table.
  • The Output Linear Units parameter specifies the units that will be used for shared boundary lengths between neighbors. The default is to use the same units as defined by the input feature coordinate system.
  • The Output Area Units parameter is only used when the Include area overlaps parameter is checked. When Include area overlaps is checked, the units used to calculate the area overlap of neighbors are specified in the Output Area Units parameter. The default is to use the same units as defined by the input feature's coordinate system.
  • The Output Table parameter value can be a file geodatabase table or a .dbf table.
  • For each field specified in the Report By Fields parameter, the output table will contain two fields using the following naming convention: src_<field> and nbr_<field>. The fields represent the source and neighbor field values from the input.
    The output table will also contain the following fields:
    • AREA—This field stores the total overlapping area between a source polygon and a neighbor polygon (overlapping neighbors). This field is included in the output table only when the Include area overlaps parameter is checked.
    • LENGTH—This field stores the total length of coincident edges between a source polygon and a neighbor polygon.
    • NODE_COUNT—This field stores the number of times a source polygon and a neighbor polygon cross or touch at a point.
  • If there is a selection set on the input features, only selected features will be analyzed.
Parameters
Label Explanation Data type
Input Features
The input polygon features.
Feature Layer
Output Table
The output table.
Table
Report By Fields
(Optional)
The input attribute field or fields that will be used to identify unique polygons or polygon groups and represent them in the output.
Field
(Optional)
Specifies whether overlapping area relationships will be analyzed and included in the output.
  • Checked—Overlapping area relationships will be analyzed and included in the output.
  • Unchecked—Overlapping area relationships will not be analyzed or included in the output. This is the default.
Boolean
(Optional)
Specifies whether both sides of neighbor relationships will be included in the output.
  • Checked—For a pair of neighboring polygons, both the neighboring information of one polygon being the source and the other being the neighbor and the reciprocal relationship will be included. This is the default.
  • Unchecked—For a pair of neighboring polygons, only the neighboring information of one polygon being the source and the other being the neighbor will be included. The reciprocal relationship will not be included.
Boolean
XY Tolerance
(Optional)
The minimum distance between coordinates before they will be considered equal. By default, this is the x,y tolerance of the input features.
Caution:
Changing this parameter's value may cause failure or unexpected results. It is recommended that you do not modify this parameter. It has been removed from view on the tool dialog box. By default, the input feature class's spatial reference x,y tolerance property is used.
Linear Unit
Output Linear Units
(Optional)
Specifies the units that will be used to report the total length of the coincident edge between neighboring polygons. The default is the input feature units.
  • Unknown—The length unit will be unknown.
  • Kilometers—The length unit will be kilometers.
  • Meters—The length unit will be meters.
  • Decimeters—The length unit will be decimeters.
  • Centimeters—The length unit will be centimeters.
  • Millimeters—The length unit will be millimeters.
  • Statute Miles—The length unit will be statute miles.
  • International Nautical Miles—The length unit will be international nautical miles.
  • International Yards—The length unit will be international yards.
  • International Feet—The length unit will be international feet.
  • International Inches—The length unit will be international inches.
  • US Survey Miles—The length unit will be US survey miles.
  • US Survey Nautical Miles—The length unit will be US survey nautical miles.
  • US Survey Yards—The length unit will be US survey yards.
  • US Survey Feet—The length unit will be US survey feet.
  • US Survey Inches—The length unit will be US survey inches.
  • Decimal Degrees—The length unit will be decimal degrees.
  • Points—The length unit will be points.
String
Output Area Units
(Optional)
Specifies the units that will be used to report the area overlap of neighboring polygons. The default is the input feature units. This parameter is only active when the Include area overlaps parameter is checked.
  • Unknown—The area unit will be unknown.
  • Square Kilometers—The area unit will be square kilometers.
  • Square Meters—The area unit will be square meters.
  • Square Decimeters—The area unit will be square decimeters.
  • Square Centimeters—The area unit will be square centimeters.
  • Square Millimeters—The area unit will be square millimeters.
  • Square Statute Miles—The area unit will be square statute miles.
  • Square International Nautical Miles—The area unit will be square international nautical miles.
  • Square International Yards—The area unit will be square international yards.
  • Square International Feet—The area unit will be square international feet.
  • Square International Inches—The area unit will be square international inches.
  • Square US Survey Miles—The area unit will be square US survey miles.
  • Square US Survey Nautical Miles—The area unit will be square US survey nautical miles.
  • Square US Survey Yards—The area unit will be square US survey yards.
  • Square US Survey Feet—The area unit will be square US survey feet.
  • Square US Survey Inches—The area unit will be square US survey inches.
  • US Survey Acres—The area unit will be US survey acres.
  • Hectares—The area unit will be hectares.
  • Acres—The area unit will be international acres.
  • Ares—The area unit will be ares.
String
Environments
Auto Commit, Maintain fully qualified field names, Extent, Scratch Workspace, Current Workspace, Parallel Processing Factor
Special cases
This tool honors the Parallel Processing Factor environment. If the environment is not set (the default) or is set to 0, parallel processing will be disabled; parallel processing will not be used and processing will be done sequentially. Setting the environment to 100 will enable parallel processing; parallel processing will be used and processing will be done in parallel. Up to 10 cores will be used when parallel processing is enabled.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
