An overview of the Analyze Patterns toolset
The Analyze Patterns toolset contains tools that identify, quantify, and visualize spatial patterns in feature data.
This toolset uses distributed processing to complete analytics on your GeoAnalytics Server.
Legacy:
ArcGIS GeoAnalytics Server is being deprecated in ArcGIS Enterprise. The final release of GeoAnalytics Server was included with ArcGIS Enterprise 11.3.
These tools are available through ArcGIS Enterprise 11.3 and earlier versions when you have an active ArcGIS Enterprise portal that has GeoAnalytics Server configured for the Feature Analysis - GeoAnalytics Tools setting. To access and run the tools, you must have spatial analysis privileges.
These tools can be accessed from either the Analysis ribbon or the Portal tab in the Geoprocessing pane.
Learn more about portal tools
Tool
Calculate Density
Calculates a magnitude-per-unit area from point features that fall within a neighborhood around each cell.
Create Space Time Cube
Summarizes a set of points into a netCDF data structure by aggregating them into space-time bins. Within each bin, the points are counted, and specified attributes are aggregated. For all bin locations, the trend for counts and summary field values are evaluated.
Find Hot Spots
Given a set of features, identifies statistically significant hot spots and cold spots using the Getis-Ord Gi* statistic.
Find Point Clusters
Finds clusters of point features in surrounding noise based on their spatial or spatiotemporal distribution.
Forest-based Classification and Regression
Creates models and generates predictions using an adaptation of the random forest algorithm, which is a supervised machine learning method developed by Leo Breiman and Adele Cutler. Predictions can be performed for both categorical variables (classification) and continuous variables (regression). Explanatory variables can take the form of fields in the attribute table of the training features. In addition to validation of model performance based on the training data, predictions can be made to features.
Generalized Linear Regression
Performs generalized linear regression (GLR) to generate predictions or to model a dependent variable in terms of its relationship to a set of explanatory variables. This tool can be used to fit continuous (OLS), binary (logistic), and count (Poisson) models.
Geographically Weighted Regression
Performs Geographically Weighted Regression (GWR), which is a local form of linear regression that is used to model spatially varying relationships.
