An overview of the Find Locations toolset
This tools in this toolset are used to identify areas that meet specified criteria. The criteria can be based on attribute queries (for example, parcels that are vacant) and spatial queries (for example, within 1 kilometer of a river). The areas that are found can be selected from existing features (such as existing land parcels), or features can be created when all the requirements are met.
This toolset uses distributed processing to complete analytics on GeoAnalytics Server.
Legacy:
ArcGIS GeoAnalytics Server is being deprecated in ArcGIS Enterprise. The final release of GeoAnalytics Server was included with ArcGIS Enterprise 11.3.
These tools are available through ArcGIS Enterprise 11.3 and earlier versions when you have an active ArcGIS Enterprise portal that has GeoAnalytics Server configured for the Feature Analysis - GeoAnalytics Tools setting. To access and run the tools, you must have spatial analysis privileges.
These tools can be accessed from either the Analysis ribbon or the Portal tab in the Geoprocessing pane.
Tool |
Description |
Creates a layer that detects features that meet a given condition. |
Finds locations where moving objects have stopped, or dwelled, using given time and distance thresholds. |
Identifies the candidate features that are most similar or dissimilar to one or more input features based on feature attributes. |
