An overview of the Use Proximity toolset
The Use Proximity toolset contains tools for answering the spatial analysis question, What is near what?
This toolset uses distributed processing to complete analytics on a GeoAnalytics Server.
Legacy:
ArcGIS GeoAnalytics Server is being deprecated in ArcGIS Enterprise. The final release of GeoAnalytics Server was included with ArcGIS Enterprise 11.3.
These tools are available through ArcGIS Enterprise 11.3 and earlier versions when you have an active ArcGIS Enterprise portal that has GeoAnalytics Server configured for the Feature Analysis - GeoAnalytics Tools setting. To access and run the tools, you must have spatial analysis privileges.
These tools can be accessed from either the Analysis ribbon or the Portal tab in the Geoprocessing pane.
Learn more about portal tools
Tool
Create Buffers
Creates buffers around input features to a specified distance.
Group By Proximity
Groups features that are within spatial or spatiotemporal proximity to each other.
Snap Tracks
Snaps input track points to lines using a process commonly referred to as map matching. The time-enabled point data must include features that represent an instant in time. Traversable lines with fields indicating the from and to nodes are required for analysis.
Trace Proximity Events
Traces events that are near each other in space (location) and time. The time-enabled point data must include features that represent an instant in time.
