Thin Road Network (Cartography Tools)
Summary
Generates a simplified road network that retains connectivity and general character for display at a smaller scale.
This tool does not generate new output. It assigns values in the input data's Invisibility Field parameter value to identify features that are extraneous. These features can then be removed from view to result in a simplified, yet representative, collection of roads. No feature geometry is altered or deleted.
Features are not actually deleted by Thin Road Network. To actually remove features, consider using the Trim Line tool.
The resulting simplified road collection is determined by feature significance, importance, and density. Segments that participate in very long itineraries across the extent of the data are more significant than those required only for local travel. Road classification, or importance, is specified by the Hierarchy Field parameter. The density of the resulting street network is determined by the Minimum Length parameter, which corresponds to the shortest segment that is visually sensible to show at scale.
See How Thin Road Network works to learn more and review a table of recommended minimum length values to use as a starting point.
Caution:
A warning is issued if the input features are not in a projected coordinate system. This tool relies on linear distance units, which will create unexpected results in an unprojected coordinate system. It is recommended that you run this tool on data in a projected coordinate system to ensure valid results. An error occurs and the tool will not process if the coordinate system is missing or unknown.
Illustration
Usage
The invisibility field must be present and named the same for all input feature classes. The data type must be short or long integer. Features that should remain visible are assigned a value of 0; those that should be removed from the display are assigned a value of 1. Use a layer definition query or a selection to display the resulting simplified collection (for example,
invisibility <> 1). You can use multiple invisibility fields to store multiple results—corresponding to various output scales—on the same feature class.The
hierarchyfield identifies the relative importance of features to help establish which features are significant. That significance is inversely proportional to the ratio between the hierarchy values. A hierarchy value of 1 indicates the most important features, with importance decreasing as hierarchy value increases. For optimal results, use no more than five levels of hierarchy. Input roads with Hierarchy = 0 are considered locked and will remain visible, along with adjacent roads necessary for connectivity. Thehierarchyfield must be present and named the same for all input feature classes. The data type must be short or long integer.The hierarchy is typically derived from a field that specifies road classification. It is not related to the concept of hierarchy used in network analysis. Hierarchy values equal to NULL are not accepted by the tool and will produce an error.
The Minimum Length parameter defines a sense of the resolution or granularity of the resulting simplified road collection. It should correspond to a length that is visually significant to include at the final scale. The results of this tool are a balanced compromise between the requirements posed by hierarchy, visibility locking, resolution, and morphology and connectivity of the road geometry. Therefore, the minimum length value cannot necessarily be measured directly in the resulting feature set.
Processing large road datasets or a number of datasets together may exceed memory limitations. In this case, consider processing input data by partition by identifying a relevant polygon feature class in the Cartographic Partitions environment setting. Portions of the data, defined by partition boundaries, will be processed sequentially. The resulting feature classes will be seamless and consistent at partition edges. See How Thin Road Network works for more information about running this tool with partitioning.
The integrity of the results of this tool relies on the topological integrity of the inputs. Proper connections must exist at intersections to accurately represent the connectivity of the road network. See How Thin Road Network works for more information about data requirements.
Parameters
| Label | Explanation | Data type |
Input Road Features |
The input linear roads that will be thinned to create a simplified collection for display at smaller scales. |
Feature Layer |
Minimum Length |
An indication of the shortest road segment that is sensible to display at the output scale. This controls the resolution, or density, of the resulting road collection. If the units are in points, millimeters, centimeters, or inches, the value is considered in page units and the reference scale is taken into account. |
Linear Unit |
Invisibility Field |
The field that stores the results of the tool. Features that participate in the resulting simplified road collection have a value of 0 (zero). Those that are extraneous have a value of 1. A layer definition query can be used to display the resulting road collection. This field must be present and named the same for each input feature class. The data type must be short or long integer. |
String |
Hierarchy Field |
The field that contains hierarchical ranking of feature importance in which 1 is very important and larger integers reflect decreasing importance. A value of 0 forces the feature to remain visible in the output collection. This field must be present and named the same for each input feature class. The data type must be short or long integer. Hierarchy values equal to NULL are not accepted and will produce an error. |
String |
Derived output
Updated Input Road Features |
The updated input road features. |
Feature Layer |
Environments
Cartographic Coordinate System, Reference Scale, Cartographic Partitions
Special cases
- Reference Scale
The reference scale is only considered when the Minimum Length parameter is entered in page units. When the reference scale is available, the detection of false dead ends is based on feature separation of 0.5 mm at scale. Otherwise, a value twice the tolerance of the spatial reference is used.
Licensing information
- Basic: No
- Standard: No
- Advanced: Yes
