An overview of the Conversion toolbox
The Conversion toolbox contains tools that convert data between various formats.
Toolset |
Description |
The Excel toolset contains tools to convert Microsoft Excel files to and from tables. |
The From PDF toolset contains a tool that exports a |
With the tools in the From Raster toolset, you can convert the information in a raster dataset to a different type of data structure, such as a feature class, or to a different type of file, such as a binary or text file. |
This toolset provides a tool to convert the features from WFS into a feature class to provide more functionality for those features. |
The GPS toolset contains tools to convert between GPS Exchange Format (GPX) and feature classes. |
The Graphics toolset contains tools that convert between graphics layers and feature classes. |
The JSON toolset contains tools to convert features between JSON (JavaScript Object Notation) or GeoJSON and feature classes. JSON and GeoJSON are text-based, lightweight interchange data formats that are used to share GIS data between ArcGIS and other systems. These formats are language-agnostic, and most programming languages—such as Python, C#, Java, JavaScript, and so on—provide libraries to read, manipulate, and write JSON and GeoJSON. |
The KML toolset contains tools to convert from Keyhole Markup Language (KML) to features in a geodatabase. |
The Point Cloud toolset contains tools for converting between different LAS format files, interpolating raster surfaces from point clouds, and creating point cloud data from an integrated mesh. |
The SAS toolset contains tools to convert SAS datasets to and from tables. |
Tools in the To CAD toolset convert geodatabase features to native CAD formats. You can use these tools in geoprocessing models and scripts to define your own conversion procedures. |
COLLADA—which stands for COLLAborative Design Activity—is an open-standard XML format for storing 3D models. It is often used as an interchange format for 3D applications, and is the format for 3D textured objects stored inside KML. COLLADA files have the |
The To dBASE toolset contains a tool that converts attribute tables to dBASE tables. |
The To Geodatabase toolset contains tools that convert and write data to a geodatabase format. |
The To GeoPackage toolset contains a tool to convert datasets into the OGC GeoPackage format. |
The To Parquet toolset contains a tool to export data to an Apache Parquet file. |
Raster information can be stored in several data file formats that can be read by ArcGIS. With the To Raster toolset, you can convert these files into raster datasets. The toolset also contains tools that allow you to convert different types of feature information into rasters. |
A shapefile is a simple, nontopological format for storing the geometric location and attribute information of geographic features. Geographic features in a shapefile can be represented by points, lines, or polygons (areas). |
