Conversion toolbox history
The tables below catalog changes made to every tool in the toolbox. There is one table per tool and you can click the tool name to go to the tool reference page.
For more information about how to interpret and use these tables, see Toolbox history topics.
Version |
Description |
1.2 |
New at this version |
Version |
Description |
1.4 |
ASCII to Raster
Version |
Description |
2.5 |
Deprecated This is a deprecated tool. The Copy Raster tool can now be used to convert an ASCII file representing raster data to a raster dataset. |
1.0 |
Ported from ArcMap 10.3 |
Version |
Description |
3.7 |
Parameter |
3.2 |
New parameter added: |
2.5 |
Version |
Description |
1.3 |
Connect Network Dataset Transit Sources To Streets
Version |
Description |
2.9 |
Deprecated Tool removed or moved to another toolbox. Now installed with the Public Transit toolbox. |
2.4 |
Version |
Description |
3.3 |
Parameter |
2.8 |
2 new parameters added:
2.4 |
5 parameters removed:
Parameter order changed at parameter 1:
Default value for parameter Parameter Parameter |
2.3 |
Version |
Description |
3.7 |
Version |
Description |
3.7 |
Version |
Description |
3.7 |
Version |
Description |
3.7 |
DEM to Raster
Version |
Description |
2.5 |
Deprecated This is a deprecated tool. The Copy Raster tool can now be used to convert a DEM file representing raster data to a raster dataset. |
2.3 |
New environment added: |
1.0 |
Version |
Description |
3.4 |
The label of the The parameter If the Support for Named Ranges added:
2.7 |
1.0 |
Version |
Description |
3.0 |
Version |
Description |
3.0 |
Version |
Description |
2.2 |
1.2 |
Version |
Description |
3.2 |
Version |
Description |
2.5 |
2.4 |
License changed from New parameter added: Parameter removed: Parameter order changed at parameter 22:
2.3 |
Version |
Description |
2.5 |
2.4 |
2.3 |
Version |
Description |
2.6 |
Version |
Description |
2.9 |
Features To GTFS Shapes
Version |
Description |
2.9 |
2.6 |
Features To GTFS Stops
Version |
Description |
2.9 |
2.2 |
Feature Class To Feature Class
Version |
Description |
3.2 |
Deprecated This is a deprecated tool. This functionality has been replaced by the Export Features tool. |
1.3 |
Environment added: Maintain Attachments |
1.0 |
Version |
Description |
1.0 |
Version |
Description |
1.0 |
Version |
Description |
2.3 |
1.0 |
Version |
Description |
2.4 |
2.2 |
1.3 |
1.0 |
Float to Raster
Version |
Description |
2.5 |
Deprecated This is a deprecated tool. The Copy Raster tool can now be used to convert a float file representing raster data to a raster dataset. |
1.0 |
Generate Shapes Features From GTFS
Version |
Description |
2.9 |
2.6 |
Version |
Description |
2.9 |
1.0 |
Version |
Description |
2.9 |
GTFS Shapes To Features
Version |
Description |
2.9 |
2.2 |
GTFS Stops To Features
Version |
Description |
2.9 |
2.2 |
GTFS To Network Dataset Transit Sources
Version |
Description |
3.4 |
2.9 |
2.5 |
2.4 |
Version |
Description |
2.2 |
1.0 |
Version |
Description |
3.6 |
Version |
Description |
3.2 |
1.3 |
Parameter |
1.0 |
Version |
Description |
1.0 |
Version |
Description |
2.7 |
Parameter
Parameter |
1.4 |
1.3 |
Parameter
1.0 |
Version |
Description |
3.0 |
2.7 |
Version |
Description |
3.4 |
Version |
Description |
2.4 |
Version |
Description |
3.0 |
1.0 |
Version |
Description |
2.9 |
2.3 |
1.0 |
Version |
Description |
2.9 |
Version |
Description |
3.0 |
Version |
Description |
2.7 |
2.3 |
1.0 |
Version |
Description |
2.7 |
2.3 |
1.0 |
Version |
Description |
2.7 |
2.3 |
1.0 |
Version |
Description |
2.3 |
1.0 |
Version |
Description |
2.3 |
1.0 |
Version |
Description |
1.0 |
Version |
Description |
1.0 |
Version |
Description |
1.0 |
Version |
Description |
2.1 |
Two new parameters added:
1.0 |
Version |
Description |
1.0 |
Version |
Description |
3.1 |
2.9 |
2.8 |
Version |
Description |
1.0 |
Version |
Description |
2.2 |
Supports Office Open XML format ( The extension of the output file controls the Excel format. If the extension is |
1.0 |
Version |
Description |
1.0 |
Version |
Description |
3.1 |
2.9 |
2.8 |
Table To Table
Version |
Description |
3.2 |
Deprecated This is a deprecated tool. This functionality has been replaced by the Export Table tool. |
1.3 |
1.0 |
Version |
Description |
2.9 |
2.6 |
Parameter
Parameter
Parameter
2.5 |
2.4 |
4 new parameters added:
Parameter |
1.0 |
