Feature Class To Geodatabase (Conversion Tools)
Summary
Converts one or more feature classes or feature layers to geodatabase feature classes.
Usage
  • The name of the output feature classes will be based on the name of the input feature class. For example, if the input is C:\base\streams.shp, the output feature class will be named streams.
  • If the name of an output feature class already exists in the output geodatabase, and the Allow geoprocessing tools to overwrite existing datasets option is unchecked, a number will be appended to the end of the feature class name to make it unique (for example, rivers_1). If any of the input feature classes have the same name, a number will also be appended to the output feature class names, regardless of the overwrite existing datasets option. Otherwise, the feature class will be overwritten.
  • To transfer domains, subtypes, attribute rules, field groups, and contingent values to the output geodatabase, check the Transfer Geodatabase Field Properties environment.
  • This tool does not support annotation.
Parameters
Label Explanation Data type
Input Features
One or more feature classes or feature layers that will be imported into a geodatabase.
Feature Layer
Output Geodatabase
The output or destination geodatabase.
Feature Dataset; Workspace
Derived output
Updated Geodatabase
The geodatabase, or geodatabase feature dataset, containing the new feature classes.
Workspace; Feature Dataset
Environments
Current Workspace, Scratch Workspace, Output Coordinate System, Geographic Transformations, Extent, XY Resolution, XY Tolerance, Output has M values, M Resolution, M Tolerance, Output has Z values, Default Output Z Value, Z Resolution, Z Tolerance, Maintain fully qualified field names, Output CONFIG Keyword, Auto Commit, Output XY Domain, Output M Domain, Output Z Domain, Transfer Field Domain Descriptions, Transfer Geodatabase Field Properties, Preserve Global IDs
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
