Map To KML (Conversion Tools)
Summary
Converts a map containing feature or raster layers to KML format (.kmz file). The output KML will contain a translation of Esri feature geometries, raster cells, layer symbology, and other properties.
Learn more about KML support in ArcGIS
Usage
  • The output .kmz file is an archive or .zip file containing a .kml file and other supplemental files. A .kmz file can be read by many applications including ArcGIS Earth and Google Earth.
  • You can control the appearance of KML in the following two ways:
    • By default, the pop-up display is composed of all visible fields from the layer. Pop-up displays can also be set using the layer's customized pop-ups. If the layer pop-ups have not been customized, the values in the feature layer's PopupInfo field are shown in the pop-up when a KML feature is clicked. These values can be numeric or text attributes as well as HTML code stored in a text field.
    • When the layer properties are not set and the feature class contains certain attributes (fields), the field properties are used in creating the KML layers that were originally created using the KML To Layer tool including attributes that define how KML is created. See KML conversion for more information about creating KML from attributes.
  • If the input has scale-dependent display properties, reduce the size of the output .kmz file by providing an appropriate Map Output Scale parameter value.
  • The input map's layers will be projected to WGS84, as all .kmz files must use that coordinate system. To ensure that the projection locates features and raster cells accurately, you may need to specify the geographic transformation environment. Alternatively, use the Project tool to re-project the map's layers to WGS84 with a valid transformation before to converting to KML.
  • The Map Output Scale and Size of Returned Image (Pixels) parameters are used together to create tiled output. For example, for an image with a size of 7000 by 5000 pixels, and a Size of Returned Image (Pixels) parameter value of 1000 pixels, the output image will be composed of 7 x 5, or 35, subimages. If the Map Output Scale parameter value is 1, each subimage will be 1000 by 1000 pixels. If the Map Output Scale parameter value is 10, each subimage will be 100 by 100 pixels.
  • To include a legend in the output KML as a screen overlay, specify a value for the Legend Layout Source parameter. You must have a legend element in a layout in the map.
    Only legend elements will become screen overlays in KML. Each legend will become a subfolder under the main KML folder when viewing the KML data.
Parameters
Label Explanation Data type
Input Map
The map, scene, or basemap that will be converted to KML.
Map
Output File (KMZ)
The output KML file, which is compressed and has a .kmz extension.
File
Map Output Scale
(Optional)
The scale at which each layer in the map will be exported.
This parameter is important with any scale dependency, such as layer visibility or scale-dependent rendering. If the layer is not visible at the output scale, it is not included in the output KML. Any value, such as 1, can be used if there are no scale dependencies.
For raster layers, a value of 0 can be used to create one untiled output image. If a value greater than or equal to 1 is used, it determines the output resolution of the raster. This parameter has no effect on layers that are not raster layers.
Only numeric characters are accepted; for example, enter 20000 as the scale, not 1:20000. In languages that use commas as the decimal point, 20,000 is also acceptable.
If you're exporting a layer that is to be displayed as 3D vectors and the Return single composite image parameter is checked, you can set this parameter to any value as long as the features do not have any scale-dependent rendering.
Double
(Optional)
Specifies whether the output KML will contain a single composite image or separate layers.
  • Checked—The output KML will contain a single image that composites all the features in the map into a single raster image. The raster is draped over the terrain as a KML GroundOverlay. This option reduces the size of the output KML. Individual features and layers in the KML are not selectable.
  • Unchecked—The output KML will contain separate, individual layers. This is the default. Whether the layers are returned as rasters or as a combination of vectors and rasters is determined by the Convert features to images parameter value.
Boolean
(Optional)
Specifies whether each feature layer in the map will be converted to a separate raster image or preserved as features. This parameter is not used if the Return single composite image parameter is checked.
  • Checked—Feature layers will be converted to a separate raster image in the KML output. Normal raster layers are also added to the KML output. Each output KML raster layer is selectable, and its transparency can be adjusted in certain KML viewer applications.
  • Unchecked—Features will be preserved in the output KML as feature geometries. This is the default.
Boolean
Extent
(Optional)
The geographic extent of the layer to be converted. Only features or raster cells in this extent will be included in the output KML.
  • Current Display Extent Map View—The extent will be based on the active map or scene.
  • Draw Extent Square and Finish—The extent will be based on a rectangle drawn on the map or scene.
  • Extent of a Layer Layer—The extent will be based on an active map layer. Choose an available layer or use the Extent of data in all layers option. Each map layer has the following options:
    • All Features Select All—The extent of all features.
    • Selected Features Area from Selected Features—The extent of the selected features.
    • Visible Features Extent Indicator—The extent of visible features.
  • Browse Browse—The extent will be based on a dataset.
  • Clipboard Paste—The extent can be copied to and from the clipboard.
    • Copy Extent Copy—Copies the extent and coordinate system to the clipboard.
    • Paste Extent Paste—Pastes the extent and coordinate system from the clipboard. If the clipboard does not include a coordinate system, the extent will use the map's coordinate system.
  • Reset Extent Reset—The extent will be reset to the default value.
When coordinates are manually provided, the coordinates must be numeric values and in the active map's coordinate system. The map may use different display units than the provided coordinates. Use a negative value sign for south and west coordinates.
Extent
(Optional)
The size of the tiles for raster layers if the Map Output Scale parameter value is greater than or equal to 1. This parameter no effect on layers that are not raster layers.
Long
Output Image DPI
(Optional)
The device resolution for any rasters in the output KML document. Typical screen resolution is 96 dpi. If the data in the map supports a high resolution and the KML requires it, consider increasing the value. Use this parameter with the Size of Returned Image (Pixels) parameter to control output image resolution. The default value is 96.
Long
Clamp features to ground
(Optional)
Specifies whether the z-values of the input features will be ignored and all features will be located, or clamped, at the ground elevation.
  • Checked—The z-values of the input features will be ignored and all features will be located, or clamped, at the ground elevation. If the input features do not have z-values, they will always be clamped to the ground. This is the default.
  • Unchecked—The z-values of the features will be maintained in the output KML. The features will be drawn in KML clients relative to sea level.
Boolean
(Optional)
The name of the layout that contains legend elements that will be included in the KML output as screen overlays.
String
Environments
Current Workspace, Extent, Scratch Workspace, Maintain Attachments, Geographic Transformations
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
