KML To Layer (Conversion Tools)
Summary
Converts a .kml or .kmz file into datasets in a geodatabase and a layer file. The layer file maintains the symbology of the input .kml or .kmz file.
Learn more about KML support in ArcGIS
Usage
  • The output datasets will be named Points, Lines, Polygons, or Multipatches, depending on the feature types in the input file.
    Each feature class created will have attributes that contain information about the input file. The original folder structure, name, and pop-up information, as well as fields that help define how the features sit on a surface, compose the attributes of each feature.
  • The output layer file maintaining the original KML symbology will be created in the target folder.
  • Rasters, or ground overlays, will be converted to a mosaic dataset in the output geodatabase. The source raster in its native format will be copied to a GroundOverlays folder in the target folder. Ground overlays are not converted by default. Use the Include ground overlay parameter to create rasters.
    License:
    Use of the Include ground overlay parameter to create a mosaic dataset requires a Desktop Standard license.
    Converting overlays using this tool may take a long time, depending on the source data. All available rasters and overlays in the KML will be converted. All of the imagery will be converted if a KML references a service that provides imagery. Highly detailed imagery may also take a long time to convert due to its file size.
  • Output datasets will be in the WGS84 coordinate system. Feature classes can be reprojected to another coordinate system using the Project tool.
  • Most input up to KMZ version 2.2 of the OGC KML standard is supported. Point locations that use the address tag (by way of geocoding) are not supported. A valid latitude and longitude location is required in the source KML.
  • ArcGIS Pro supports adding KML and KMZ layers to the map in their original format without conversion. However, to perform editing or to modify the layers in any way, the layer must be converted using this tool. You can select the KML layer as the input to this tool.
Parameters
Label Explanation Data type
Input File (KML or KMZ)
The .kml or .kmz file that will be converted to geodatabase datasets.
File; KML Layer
Target Folder
The destination folder where the output geodatabase and layer file (.lyrx) will be created.
Folder
Output Name
(Optional)
The name that will be used for both the output geodatabase and layer file (.lyrx). The default is the name of the input file.
You can specify the name of an existing geodatabase in the target folder, and the conversion will write new datasets into the existing geodatabase. If the geodatabase with the specified name does not exist, it will be created in the target folder.
String
(Optional)
Specifies whether ground overlays from the KML will be included in the output.
Use caution if the KMZ points to a service that serves imagery. The tool will attempt to convert the raster imagery at all available scales. This process may be lengthy and possibly overwhelm the server or time out.
  • Checked—Ground overlays will be included in the output.
  • Unchecked—Ground overlays will not be included in the output. This is the default.
Boolean
Output Suffix
(Optional)
The suffix that will be added to the names of all output feature datasets, feature classes, mosaic datasets, and layer files. If no suffix is specified, the name of the feature dataset in the output geodatabase will be Placemarks.
String
Derived output
Output Layer File
The output layer file.
Group Layer
Output Geodatabase
The output geodatabase containing feature classes in a feature dataset, and a mosaic dataset if ground overlays were included.
Workspace
Environments
Current Workspace, Scratch Workspace, Output has Z values
Licensing information
  • Basic: Limited
    Some parameters are limited by license level.
  • Standard: Yes
  • Advanced: Yes
