KML conversion
Keyhole Markup Language (KML) is an XML-based format that stores geographic data and related content. The format is an official Open Geospatial Consortium (OGC) standard. Organizations use the KML format to share geographic data with non-GIS users. The format is easy to distribute online and view in free applications.
Files that use the KML format have either a .kml or .kmz file extension. The .kmz extension indicates a compressed version of a .kml file. Both file types work and can be viewed in the same way.
KML supports a combination of elements, including points, lines, polygons, and raster imagery. A single file can contain features of different types and imagery. The format also includes related content such as graphics, pictures, attributes, and HTML.
You can use geoprocessing tools to convert a map layer to KML and convert KML to a geodatabase. This lets you view, edit, and analyze the geographic data contained in any .kml or .kmz file. ArcGIS Pro supports all of the features from the KML 2.0 and 2.1 specifications. However, it does not currently support features introduced in KML 2.2, such as time animation, photo overlays, and schema tags.
KML terminology
Common KML terminology is defined in the following table:
Term
Path
A line feature.
Placemark
A point feature or location on a point, line, or polygon feature that can be clicked to display pop-up information.
Polygon
A polygon feature.
Ground overlay
A raster or image that is typically georeferenced and draped on the earth's surface. Examples of ground overlays include aerial imagery, feature layers, and maps converted to an image.
Screen overlay
A map or screen graphic such as a logo, legend, or picture. Screen overlays are not part of the geographic display but are useful as information displays.
Tag
As KML is an XML-based format, its structure is based on various tags. For example, each point feature in a .kml file is inside a <Placemark> tag. The <Placemark> tag has subtags, such as <Name>, <Snippet>, and <Description>, which store information about the point, as well as a <Point> subtag that stores the x-, y-, and z-coordinates.
Convert from KML
Use the KML To Layer tool to convert a .kml or .kmz file to a file geodatabase containing all features and imagery from the source KML and a layer file that maintains the colors and symbols of the source KML. In addition to the KML feature and imagery data and symbology, several other properties of the KML will also be included in the converted ArcGIS data, such as pop-up information, snippets, and other attributes. After performing this conversion, you can use the geographic data from your KML file in the same ways you would any other GIS data: edit, analyze, and map it.
Use the KML To Geodatabase tool to convert a .kml or .kmz file to the appropriate point, polyline, or polygon outputs. Compared with KML To Layer tool, this tool supports importing KML attributes in Extended Data node to feature class attributes fields.
Convert to KML
Use the Layer To KML tool to convert any map layer to KML. KML files created by this tool will be a snapshot of your data at the time the layer was converted. After creating the KML, you can share it with others who can view it in an application such as Google Earth.
Before running the Layer To KML tool, symbolize the layer and set certain properties and modify specific data attributes. Many aspects and properties of layers are applied to the KML during conversion, including visible attribute fields, transparency, labels, pop-up displays, and symbology. By setting layer properties and data attributes, you ensure that the KML you create matches your expectations, is easy to interpret, and is well formed. Except where noted below, the rule of converting a layer to KML is what you see is what you get. The following table describes things you can do to prepare the layers for conversion to KML:
Property
Layer name
A layer in ArcGIS becomes a folder in the KML. The layer name will be used as the KML folder name.
KML name
Layer description
The layer description will be used as the pop-up display content for the folder.
Layer symbology
The layer symbology will be used as the KML symbol. For feature layers, not all ArcGIS symbols are supported in KML. Consider this general rule: only simple symbols are supported.
For line features, only simple symbols with basic color and line width properties are supported; advanced effects such as dashes and arrows and multilevel or layered symbols are not supported.
Point features will export the current symbol and use a .png file to display the symbol. 3D symbols and other complex identifiers are not supported.
For polygon features, only simple color fills with simple line borders are supported; no patterned, hatching, or gradient fills are supported, and the same rules for lines apply to polygon borders. If you require more than simple symbols for your features, use the Return single composite image parameter of the Layer To KML tool to convert the symbolized features into a raster image that maintains complex symbology.
Feature name
If labels are turned on, the layer's label field or expression will be used for the feature name in the KML. If labels are not turned on, the layer's display field or expression will be used for the name. If neither of these layer properties are set, values from the Name field will be used for the name.
Feature label
If layer labels are turned on, the layer label field or expression will be used to name each KML feature and labels will be turned on.
Only point features will be labeled. For line or polygon features, centroids can be created and labeled to achieve a label effect.
Feature snippet
The snippet of a feature can be set by changing the alias of any existing field to KMLSnippet. Alternatively, values in the feature layer's Snippet field will be used as the snippet of each feature in the KML.
Feature pop-up display
By default, the pop-up display includes all visible fields from the layer. You can customize KML feature pop-up displays by configuring the layer's pop-ups. Text, fields, and attachments elements in the pop-up are supported when the layer is converted to KML. If the layer pop-ups have not been customized, all feature layer field values will appear in the KML feature pop-up. The layer's display field value will be shown as a title on the KML feature pop-up display. The display field values can be numeric or text attributes as well as HTML-formatted code stored in a text field.
Folders and subfolders
You can assign a folder structure to the layers and features in a KML. If the layer has a field named FolderPath, and the field is populated with values with multiple levels, the values in that field will be used for defining the KML folders and subfolders. The first level of the FolderPath field becomes the root folder that contains other folders. Within that field, the path separator between folders and subfolders must be a forward slash (/). If the layer does not have a FolderPath field, you can define a folder and subfolder structure using group layers. Specify the group layer as the input to the Layer To KML tool to get the group layer structure in the KML.
3D Feature elevation
A KML will be created in 3D if the feature layer is z-enabled and has z-values in the geometry. Also, when a layer has 3D display effects applied, such as base height or extrusion, those 3D effects will be maintained in the output KML. If none of these layer effects are applied, field attributes are used to control 3D effects. For a detailed explanation, see the following section on 3D creation.
Create 3D KML
The field attributes (all of type integer) described below are used to control the placement and properties of features in the 3D space (on top of or floating on a surface).
Caution:
KML uses the WGS84 coordinate system and meters for the unit of measurement. All elevation values are assumed to be in meters when creating KML.
Layer properties for 3D conversion
Field
Value
Explanation
AltMode
0 or -1
A value of 0 sets the height to the KML setting of absolute and should be used when the features are z-enabled. A value of -1 places the features relative to the surface of the earth.
Base
Any numerical value
Any numerical value can be used. When this value is used with a relative placement (AltMode=-1), the value controls the height of the features above the earth's surface.
Caution:
If the features have a z-value of 100 and are in a geographical area where the earth's surface is higher than 100, an absolute setting will cause the features to be placed under the surface of the earth.
Extruded
0 or -1
A value of 0 sets no extrusion, while -1 creates an extrusion effect. Extrusion of features makes polygons look like blocks with their sides continuing down from the polygon into the earth's surface.
The green polygons (OID 3 and 4) of the following image are features without elevation, or z-values, while the red and gray features have elevation values. Similar effects can be applied to features with and without z-values. For example, the green extruded polygon (OID 3) has no z-values and the following fields set: AltMode = -1, Base = 25, and Extruded = -1. The extruded red polygon (OID 2) has a z-value of 1300 and the following fields: AltMode = 0, Base = 0, and Extruded = -1. Because the red feature (OID 2) has an elevation value, its position is set to absolute, and only extrusion is used.
Controlling 3D behaviors
The Layer To KML tool's Clamped features to ground parameter will override 3D settings and all of the features will be draped on the earth's surface. This parameter is useful when creating KML from features with z-values below the earth's surface or when 3D effects are not required. Alternatively, using the Clamped field with a setting of -1 will produce the same effects as using the optional parameter on a per-feature basis.
