Build Multidimensional Transpose (Data Management Tools)
Summary
Transposes a multidimensional raster dataset, which divides the multidimensional data along each dimension to optimize performance when accessing pixel values across all slices.
Legacy:
This is a deprecated tool. The Build Multidimensional Transpose tool has been moved to the Multidimensional toolbox.
Usage
  • The input multidimensional raster must be in Cloud Raster Format (CRF). Currently, no other formats are supported.
  • The Build Multidimensional Transpose tool enhances performance when accessing pixel values across all slices in a large multidimensional dataset, for example when you create a temporal profile chart for daily sea surface temperature values across 10 years.
Parameters
Label Explanation Data type
Input Multidimensional Raster
The input CRF multidimensional raster dataset.
Raster Layer
Derived output
Output Multidimensional Raster
The updated CRF multidimensional raster dataset.
Raster Dataset
Environments
Parallel Processing Factor
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
