Generate Embeddings Using AI Models (GeoAI Tools)
Summary
Generates semantic embeddings for geospatial data using foundation models. The tool converts input data such as images and geographic locations into vector embeddings that capture semantic meaning. These embeddings can then be used in downstream embeddings based tools and workflows in ArcGIS Pro, such as similarity search, change detection, and find features by description.
Usage
  • This tool requires a model definition file containing model information. The Input Model Definition File parameter value can be an Esri model definition JSON file (.emd) or a deep learning model package (.dlpk). The model files can be stored locally or hosted on ArcGIS Living Atlas of the World.
  • This tool supports the use of third-party models created using the model extensibility feature. This feature enables tasks—such as generating embeddings for locations, texts, images, and so on—using custom deep learning models that were not trained with tools supported by ArcGIS Pro. To learn more about creating a custom deep learning model file, see Use third-party language models with ArcGIS.
  • This tool can run on CPU or GPU; however, deep learning is computationally intensive and a GPU is recommended. To run this tool using GPU, set the Processor Type environment to GPU. If you have more than one GPU, specify the GPU ID environment instead.
  • For information about requirements for running this tool and issues you may encounter, see Deep Learning frequently asked questions.
Parameters
Label Explanation Data type
Input Feature Class Or Raster
An input raster imagery or location feature layer for which embeddings will be generated.
Raster Dataset; Raster Layer; Mosaic Layer; Image Service; Map Server; Map Server Layer; Internet Tiled Layer; Feature Layer; Feature Class
Output Embeddings Feature Class
The output embeddings feature class storing generated embeddings in Esri-compatible embedding format.
Feature Class
The foundation model that will be used to compute embeddings. The model determines the semantic representation of raw data.
File
Arguments
(Optional)
Additional arguments that will be used by the model while performing inference.
Value table columns:
  • Grid Size—This is a model argument which defines the embedding grid size for raster inputs. One embedding is generated per embedding grid size covering the specified area in meters.
  • Text Field—Field name whose values will be converted into embeddings while generating text embeddings.
Value Table
Environments
Extent, Processor Type, GPU ID, Parallel Processing Factor
Licensing information
  • Basic: No
  • Standard: No
  • Advanced: Limited
    Requires Image Analyst for generating image embeddings
