Merge Embeddings (GeoAI Tools)
Summary
Merges embeddings from an input embeddings feature class into target polygons based on the area of overlap. Embeddings are aggregated and merged for each target polygon based on the input features that fall within it. For example, embeddings from ZIP code polygons or point-based locations can be merged into state-level polygon embeddings.
Usage
- This tool accepts two inputs, a target polygon feature layer that defines the spatial boundaries for aggregation, and a point or polygon embedding feature class generated using the Generate Embeddings Using AI Models tool. The embedding features acts as the source embeddings to be aggregated within the target polygon geometries.
Parameters
| Label | Explanation | Data type |
Target Features |
The target polygon feature layer that provides the spatial boundaries used for aggregating embeddings from the input embeddings feature class. The geometry and attributes of these features are preserved in the output, and a new embedding field will be added based on the spatial relationship with the input embedding features. |
Feature Layer |
Embedding Features |
The input embedding feature class generated using Generate Embeddings Using AI Models tool or provided in the compatible format. The embeddings in this feature class are aggregated based on the target features. It can have either point or polygon geometries. |
Feature Layer |
Output Embeddings Feature Class |
The output embedding feature class with the input embeddings aggregated as per the feature geometry in the target features. |
Feature Class |
Environments
Output Coordinate System, Geographic Transformations, Extent, Parallel Processing Factor
Licensing information
- Basic: No
- Standard: No
- Advanced: Yes
