Calculate Field (GeoAnalytics Desktop Tools)
Summary
Creates a layer with calculated field values.
Usage
  • Calculate Field is completed on tables or point, line, or polygon features.
  • Calculate Field will always create a layer. It will not modify the input. You can only calculate values for a single field at a time.
  • You can calculate values for an existing field or for a new field you add by creating a unique field name.
  • Expressions are created using Arcade expressions. See Arcade expressions in GeoAnalytics Desktop tools for more information.
  • Arcade expressions can be track aware. Track-aware expressions require that data is time enabled and of time type instant and that a track field is specified. To learn more about building track-aware expressions, see Track aware examples.
  • To include a track-aware calculation, you must do the following:
    • Use a layer that is time enabled and of time type instant.
    • Check the Track Aware check box.
    • Select the fields used to identify tracks.
  • Tracks are represented by the unique combination of one or more track fields. For example, if the flightID and Destination fields are used as track identifiers, the ID007, Solden and ID007, Tokyo features would be in two separate tracks, since they have different values for the Destination field.
  • Similar analysis can also be completed using the following:
  • Applying a time interval boundary segments tracks at a defined interval. For example, if you set the time interval boundary to 1 day, starting at 9:00 a.m on January 1, 1990, each track will be truncated at 9:00 a.m. every day and analyzed within that segment. This split accelerates computing time, as it creates smaller tracks for analysis. If splitting by a recurring time interval boundary makes sense for the analysis, it is recommended for big data processing. The analysis must be track aware to set a time boundary.
  • In addition to the calculated field, the output may include the following new field types:
    • ObjectID
    • datetime—If results are temporally enabled. The new fields are instant_date for time type instant, and start_date and end_date for time type interval.
  • You can improve performance of the Calculate Field tool by doing one or more of the following:
    • Set the extent environment so that you only analyze data of interest.
    • If you are using tracks, split the tracks using the Time Boundary Split parameter.
    • Only select Track Aware if the expression includes a track expression.
    • Use data that is local to where the analysis is being run.
  • This geoprocessing tool is powered by Spark. Analysis is completed on your desktop machine using multiple cores in parallel. See Considerations for GeoAnalytics Desktop tools to learn more about running analysis.
  • When running GeoAnalytics Desktop tools, the analysis is completed on your desktop machine. For optimal performance, data should be available on your desktop. If you are using a hosted feature layer, it is recommended that you use ArcGIS GeoAnalytics Server. If your data isn't local, it will take longer to run a tool. To use your ArcGIS GeoAnalytics Server to perform analysis, see GeoAnalytics Tools.
Parameters
Label Explanation Data type
Input Layer
The input features that will have a field calculated.
Table View
Output Dataset
A new dataset with calculated fields.
Feature Class; Table
Field to Calculate
Specifies whether values will be calculated for a newly created field or an existing field.
  • New field—Values will be calculated for a newly created field.
  • Existing field—Values will be calculated for an existing field.
String
New Field Name
(Optional)
The new field that will have values calculated.
String
Existing Field
(Optional)
The existing field that will have values calculated.
Field
Field Type
(Optional)
Specifies the field type for the calculated field.
  • String—Any string of characters
  • Integer—Whole numbers
  • Double—Fractional numbers
  • Date—Date
String
Expression
Calculates values in the field. Expressions are written in Arcade and can include [+ - * / ] operators and multiple fields. Calculated values are applied in the units of the spatial reference of the input unless you are using a geographic coordinate system, in which case they will be in meters.
If the layer is added to the map, the Fields and Helpers filters can be used to build an expression.
Calculator Expression
Track Aware
(Optional)
Specifies whether the expression will use a track-aware expression.
  • Checked—The expression will use a track-aware expression, and a track field must be specified.
  • Unchecked—The expression will not use a track-aware expression. This is the default.
Boolean
Track Fields
One or more fields that will be used to identify unique tracks.
Field
Time Boundary Split
(Optional)
A time span to split the input data into for analysis. A time boundary allows you to analyze values within a defined time span. For example, if you use a time boundary of 1 day, and set the time boundary reference to January 1, 1980, tracks will be split at the beginning of every day.
Time Unit
Time Boundary Reference
(Optional)
The reference time used to split the input data into for analysis. Time boundaries will be created for the entire span of the data, and the reference time does not need to occur at the start. If no reference time is specified, January 1, 1970, is used.
Date
Environments
Output Coordinate System, Extent, Current Workspace
Licensing information
  • Basic: No
  • Standard: No
  • Advanced: Yes
