Compute Accuracy For Object Detection (Image Analyst Tools)
Summary
Calculates the accuracy of a deep learning model by comparing the detected objects from the Detect Objects Using Deep Learning tool to ground truth data.
Learn more about how Compute Accuracy For Object Detection works.
Usage
This tool generates a table containing information regarding the accuracy of the output from the Detect Objects Using Deep Learning tool.
The table contains accuracy metrics for each class in the detected data, as well as a row for all classes (overall accuracy). The table contains the following fields:
Precision—The ratio of the number of true positives to the total number of predictions.Recall—The ratio of the number of true positives to the total number of actual (relevant) objects.F1_Score—The weighted average of the precision and recall. Values range from 0 to 1 in which 1 means highest accuracy.AP—The Average Precision (AP) metric, which is the precision averaged across all recall values between 0 and 1 at a given Intersection over Union (IoU) value.True_Positive—The number of true positives generated by the model.False_Positive—The number of false positives generated by the model.False_Negative—The number of false negatives generated by the model.
For more information about the metrics provided in the output table and in the accuracy report, see How Compute Accuracy For Object Detection works.
The input ground reference data must contain polygons. If you have point or line data indicating the location of objects, use the Buffer tool to generate a polygon feature class before running this tool.
The IoU ratio is used as a threshold for determining whether a predicted outcome is a true positive or a false positive. The IoU ratio is the amount of overlap between the bounding box around a predicted object and the bounding box around the ground reference data.
The numbers in the following table correspond to the numbers in the image above:
Number
The intersecting area of the predicted bounding box and the ground reference bounding box
The total area of the predicted bounding box and ground reference bounding box combined
Parameters
| Label | Explanation | Data type |
Detected Features |
The polygon feature class containing the objects detected from the Detect Objects Using Deep Learning tool. |
Feature Class; Feature Layer |
Ground Truth Features |
The polygon feature class containing ground truth data. |
Output Accuracy Table |
The output accuracy table. |
Table |
Output Accuracy Report (Optional) |
The name of the output accuracy report. The report is a PDF document containing accuracy metrics and charts. |
File |
Detected Class Value Field (Optional) |
The field in the detected objects feature class that contains the class values or class names. If no field name is provided, a The class values or class names must match those in the ground reference feature class exactly. |
Field |
Ground Truth Class Value Field (Optional) |
The field in the ground truth feature class that contains the class values. If no field name is provided, a The class values or class names must match those in the detected objects feature class exactly. |
Field |
Minimum Intersection Over Union (IoU) (Optional) |
The IoU ratio that will be used as a threshold to evaluate the accuracy of the object detection model. The numerator is the area of overlap between the predicted bounding box and the ground reference bounding box. The denominator is the area of union or the area encompassed by both bounding boxes. The IoU ranges from 0 to 1. |
Double |
Mask Features (Optional) |
A polygon feature class that delineates the area or areas where accuracy will be computed. Only the features that intersect the mask will be assessed for accuracy. |
Environments
Current Workspace, Extent, Scratch Workspace
Licensing information
- Basic: Requires Image Analyst
- Standard: Requires Image Analyst
- Advanced: Requires Image Analyst
