Generate Multidimensional Anomaly (Image Analyst Tools)
Summary
Computes the anomaly for each slice in an existing multidimensional raster to generate a new multidimensional raster.
An anomaly is the deviation of an observation from its standard or mean value.
Usage
  • Supported multidimensional raster datasets include Cloud Raster Format (CRF), multidimensional mosaic datasets, or multidimensional raster layers generated by netCDF, GRIB, or HDF format files.
  • This tool produces a multidimensional raster dataset in Cloud Raster Format (CRF). Currently, no other output formats are supported.
  • This tool calculates anomalies over time for one or more variables in a multidimensional raster. If you have a nontime dimension in addition to the time dimension, the anomaly will be calculated at each step in the additional dimension.
    For example, you have monthly ocean temperature data, collected every 1 meter of depth up to 100 meters, and you want to calculate the temperature anomalies as deviations from the yearly mean. The Generate Multidimension Anomaly tool will determine the temperature anomalies based on a yearly mean if you set the Mean Calculation Interval parameter to Yearly, and it will return anomaly values for each of the 100 depths.
  • This tool only supports multidimensional raster datasets that have a time dimension.
  • The mathematical methods for calculating anomaly values are listed below. Anomalies can be calculated using either the mean or the median values as the definition of the average. If the data distribution is skewed, the mean can be highly influenced by outliers, so the median value or z-score method may be better suited for this type of data.
    • Difference from mean = x - µ
      • x = pixel value in a slice
      • µ = mean of that pixel's values over the given time interval
    • Percent difference from mean = |x - µ| / [(x + µ)/2]
      • |x - µ| = absolute value of the difference between the value and the mean
    • Percent of mean = x / µ
    • Difference from median = x - ß
      • ß = median of that pixel's values over the given time interval
    • Percent difference from median = |x - ß| / [(x + ß)/2]
      • |x - ß| = absolute value of the difference between the value and the median
    • Percent of median = x / ß
    • Z-score = (x - µ) / S
      • S = the standard deviation of the pixel's values over the given time interval
  • The mean or median will either be calculated from the input multidimensional raster or you can provide the mean or median values directly as a raster input in the Mean Calculation Interval parameter. The external raster can be a single raster or a multidimensional raster. If the input is a single raster, the difference from the mean will be calculated by comparing the pixel values in each slice to the corresponding pixel value in the external raster. If the input is a multidimensional raster, corresponding slices will be compared to calculate the difference from the mean, so the number and name of the variables and dimensions must match.
    The external raster must have the same extent, cell size, and spatial reference as the input multidimensional raster.
  • The z-score anomaly calculation method is not supported if an external raster is used to calculate the difference from the mean.
Parameters
Label Explanation Data type
Input Multidimensional Raster
The input multidimensional raster dataset.
Raster Dataset; Raster Layer; Mosaic Dataset; Mosaic Layer; Image Service; File
Variables [Dimension Info] (Description)
(Optional)
The variable or variables for which anomalies will be calculated. If no variable is specified, all variables with a time dimension will be analyzed.
String
Anomaly Calculation Method
(Optional)
Specifies the method that will be used to calculate the anomaly.
  • Difference From Mean—The difference between a pixel's value and the mean of that pixel's values across slices defined by the interval will be calculated. This is the default.
  • Percent Difference From Mean—The percent difference between a pixel's value and the mean of that pixel's values across slices defined by the interval will be calculated.
  • Percent Of Mean—The percent of the mean will be calculated.
  • Z-score—The z-score for each pixel will be calculated. A z-score of 0 indicates the pixel's value is identical to the mean. A z-score of 1 indicates the pixel's value is 1 standard deviation from the mean. If a z-score is 2, the pixel's value is 2 standard deviations from the mean, and so on.
  • Difference From Median—The difference between a pixel's value and the mathematical median of that pixel's values across slices defined by the interval will be calculated.
  • Percent Difference From Median—The percent difference between a pixel's value and the mathematical median of that pixel's values across slices defined by the interval will be calculated.
  • Percent Of Median—The percent of the mathematical median will be calculated.
String
(Optional)
Specifies the temporal interval that will be used to calculate the mean.
  • All—The mean is calculated across all slices for each pixel.
  • Yearly—The yearly mean is calculated for each pixel.
  • Recurring monthly—The monthly mean is calculated for each pixel.
  • Recurring weekly—The weekly mean is calculated for each pixel.
  • Recurring daily—The daily mean is calculated for each pixel.
  • Hourly—The hourly mean is calculated for each pixel.
  • External raster—An existing raster dataset that contains the mean or median value for each pixel is referenced.
String
Ignore NoData
(Optional)
Specifies whether NoData values will be ignored in the analysis.
  • Checked—The analysis will include all valid pixels along a given dimension and ignore NoData pixels. This is the default.
  • Unchecked—The analysis will result in NoData if there are NoData values for the pixels along the given dimension.
Boolean
Input External Raster
(Optional)
The reference raster dataset that contains a previously calculated mean for each pixel. The anomalies will be calculated in comparison to this mean.
Raster Layer; Raster Dataset; Mosaic Layer; Mosaic Dataset
Return value
Output Multidimensional Raster
The output Cloud Raster Format (CRF) multidimensional raster dataset.
Raster
Environments
Cell Size, Compression, Current Workspace, Geographic Transformations, NoData, Output CONFIG Keyword, Output Coordinate System, Extent, Parallel Processing Factor, Pyramid, Raster Statistics, Resampling Method, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires Image Analyst or Spatial Analyst
  • Standard: Requires Image Analyst or Spatial Analyst
  • Advanced: Requires Image Analyst or Spatial Analyst
