An overview of the Multidimensional Analysis toolset
Available with Image Analyst license.
The tools in the Multidimensional Analysis toolset allow you to perform analysis on scientific raster data across multiple variables and dimensions.
Multidimensional data represents data captured at multiple times, depths, and heights. This type of data is commonly used in atmospheric, oceanographic, and earth sciences. The data structure is sometimes referred to as a data cube or an image cube. In ArcGIS Pro, you can manage, visualize, and analyze multidimensional raster data in multiple formats including netCDF, HDF, GRIB, the multidimensional mosaic dataset, and Esri's Cloud Raster Format (CRF).
The following table lists the multidimensional analysis tools and provides a brief description of each.
Tool |
Description |
Generates a multidimensional raster dataset by combining existing multidimensional raster variables along a dimension. |
Calculates statistics over a moving window on multidimensional data along a specified dimension. |
Extracts the dimension value or band index at which a given statistic is attained for each pixel in a multidimensional or multiband raster. |
Computes the anomaly for each slice in an existing multidimensional raster to generate a new multidimensional raster. |
Estimates the trend for each pixel along a dimension for one or more variables in a multidimensional raster. |
Interpolates temporal point data into a multidimensional raster. |
Reduces the number of components that can account for the variance of the whole multidimensional raster so that spatial and temporal patterns can be easily identified. |
Analyzes correlations between two variables in one or two multidimensional rasters. |
Computes a forecasted multidimensional raster using the output trend raster from the Generate Trend Raster tool. |
Generates a table containing the pixel count for each class, in each slice of an input categorical raster. |
