Derive Event Measures (Linear Referencing Tools)
Summary
Populates and updates the DerivedRouteID field and measure values on point and line events with those fields configured and enabled.
Usage
  • An LRS dataset is required to run this tool.
    Learn more about creating an LRS dataset
  • This tool is designed to be run as part of a larger workflow. Run the Apply Event Behaviors and Generate Routes tools before running Derive Event Measures. Running this tool without running the previous tools in the workflow may result in inaccurate data.
  • It is recommended that you run this tool on the file geodatabase at the initial migration of the data. It will run faster this way because the operation must modify each event record in the database. Once in production, the tool can be run on a selection set of the routes that have been modified to significantly improve the performance time.
  • The input event feature layer must have the DerivedRouteID field and measure fields configured.
  • Selection sets on the input route features layer are honored.
  • Selection sets on event layers are ignored and not honored.
  • This tool can be run on one, multiple, or all events in a line network.
  • This tool supports conflict prevention and will attempt to acquire and transfer locks.
  • When conflict prevention is enabled, the following are supported:
    • The events whose derived event measures need to be updated will automatically acquire event locks if available. If the locks cannot be acquired, the tool will fail and provide the text file of those locks.
      Learn more about conflict prevention in ArcGIS Linear Referencing
    • While working in the default version, the acquired locks will be released automatically when the tool completes.
    • While working in a named version, the acquired locks will remain in On Post status when the tool completes. You must post or delete the version to release the locks.
    • While working in a named version, if the tool run is canceled by interruption, the acquired locks will remain in releasable status.
Parameters
Label Explanation Data type
Input Route Features
The LRS Network containing the events with the DerivedRouteID field and measure fields configured.
Feature Layer
Update all event feature classes registered in the selected network
(Optional)
Specifies whether all event feature classes in the network will be updated.
  • Checked—All event feature classes in the network that are selected in the Input Route Features parameter value will be updated. This is the default.
  • Unchecked—All event feature classes in the network that are selected in the Input Route Features parameter value will not be updated. Individual event layers can be selected using the Event Layers parameter.
Boolean
Event Layers
(Optional)
The event layers that will have the DerivedRouteID field and measure fields updated.
Feature Layer
Derived output
Output Events
The updated events feature layer.
Feature Layer
Output Details File
The text file that details changes made to the events feature layer.
Validation results for this tool are written to the ArcGIS Server directory. This file is automatically cleaned up in 10 minutes by default, which may not be enough time to process all of the validations and write them to your workstation that is running ArcGIS Pro. For larger data loads, it is recommended that you adjust the maximum file age to at least one hour.
Text File
Environments
Current Workspace
Licensing information
  • Basic: Requires ArcGIS Linear Referencing
  • Standard: Requires ArcGIS Linear Referencing
  • Advanced: Requires ArcGIS Linear Referencing
