Remove Overlapping Centerlines (Linear Referencing Tools)
Summary
Removes overlapping centerline sections to ensure that there is one common centerline when centerline geometry overlaps.
The ArcGIS Linear Referencing minimum schema models route concurrencies by having routes share the same centerline associations in the centerline sequence table. Running this tool may result in centerline changes, such as centerline splitting or deletion of duplicated centerline features. It may also update centerline sequence table records so that routes share centerlines.
Overlapping centerlines may result when any of the following occur:
  • A network with concurrent routes is loaded
  • An additional network is loaded
  • Ad-hoc user centerline editing
While the Remove Overlapping Centerlines tool can be run any time after an LRS Network is created and data is loaded, consider running it only after you've finished creating all LRS Networks and have loaded all data in the LRS. If additional columns are modeled on the centerlines, some centerline attributes may be lost when the tool is run.
Illustration
Remove Overlapping Centerlines tool illustration
Centerlines C1 and C2 overlap until the middle of centerline C1. After running the Remove Overlapping Centerlines tool, the overlapping portion is removed, and centerline C3 is created and associated with routes R1 and R2 in the Centerline Sequence table.
Usage
  • An LRS dataset is required to run this tool.
    Learn more about creating an LRS dataset
  • The number of centerline features in the input centerline feature layer may be different after running the tool, depending on the number of overlapping centerlines and the routes associated with them.
  • This tool uses the topological operations Intersect and Simplify together, which can cause small polyline segments of a length around and above the feature class tolerance to be lost. Associated route shapes may change slightly beyond tolerance as a result of using this tool. Consider starting an edit session in ArcGIS Pro for test runs of the tool using the Enable Undo button in the Geoprocessing pane.
    Learn more about how cluster tolerance is used in ArcGIS topological operations
  • This tool ignores z-values on the centerlines during calculations. For example, if two centerlines do not overlap in 3D space but do overlap in 2D space, they will be considered overlapping.
  • This tool supports conflict prevention and will attempt to acquire and transfer locks.
    Learn more about conflict prevention in ArcGIS Linear Referencing
Parameters
Label Explanation Data type
Input Centerline Features
An input layer or feature class representing an LRS centerline.
Feature Layer
Derived output
Updated Centerline features
The updated centerline feature layer.
Feature Layer
Output Details File
A text file that details the overlapping centerlines removed from the feature layer.
Text File
Environments
Current Workspace, Parallel Processing Factor
Special cases
The default value for this environment, if left blank, is 0%. Any absolute value for the environment is always clamped between 0 and the number of logical cores in that machine.
Licensing information
  • Basic: Requires ArcGIS Linear Referencing
  • Standard: Requires ArcGIS Linear Referencing
  • Advanced: Requires ArcGIS Linear Referencing
