Reality Mapping toolbox history
The tables below catalog changes made to every tool in the toolbox. There is one table per tool and you can click the tool name to go to the tool reference page.
For more information about how to interpret and use these tables, see Toolbox history topics.
Analyze Control Points
Version
3.1
New in the Reality Mapping toolbox. Installed in the Data Management toolbox under the Ortho Mapping toolset in prior versions.
Append Control Points
Version
3.1
Apply Block Adjustment
Version
3.2
New parameter added: adjust_tiepoints
3.1
Compute Block Adjustment
Version
3.3
Parameter adjustment_options has new option added: rigCamera
3.2
Parameter adjustment_options has 17 new options:
  • CalibrateF
  • CalibratePP
  • CalibrateP
  • CalibrateK
  • APrioriAccuracyX
  • APrioriAccuracyY
  • APrioriAccuracyZ
  • APrioriAccuracyXY
  • APrioriAccuracyXYZ
  • APrioriAccuracyOmega
  • APrioriAccuracyPhi
  • APrioriAccuracyOmegaPhi
  • APrioriAccuracyKappa
  • ComputeAntennaOffset
  • ComputeShift
  • ComputeImagePosteriorStd
  • ComputeSolutionPointPosteriorStd
3.1
Compute Camera Model
Version
3.1
Compute Control Points
Version
3.1
Compute Depth Map
Version
3.2
New at this version
Compute Tie Points
Version
3.1
Detect Control Points
Version
3.4
New at this version
Export Frame and Camera Parameters
Version
3.1
Generate Block Adjustment Report
Version
3.2
Parameter report_format has 2 new options:
  • JSON
  • BRIEF JSON
3.1
Match Control Points
Version
3.1
Reconstruct Surface
Version
3.6
Parameter recon_options has 5 new options:
  • meshSettings
  • srs
  • exportInLocalCoordinateSystem
  • exportAsSingleFile
  • dsmMeshSettings
Parameter products has new option added: GAUSSIAN_SPLATS
3.2
Parameter quality had 2 options removed:
  • MEDIUM
  • LOW
Parameter scenario has 2 new options:
  • SATELLITE
  • DRONE
Parameter scenario had DEFAULT option removed
3.1
New at this version
Remove Depth Map
Version
3.2
New at this version
