An overview of the Overlay toolset
Available with Spatial Analyst license.
Overlay analysis tools allow you to apply weights to several input layers, combine them into a single output, and subject to specifications of distribution and shape, identify preferred locations within that result. These tools are commonly used for suitability modeling.
There are several approaches for performing overlay analysis. Although the methods differ, they all follow the same general steps for solving a multicriteria problem. There is a general sequence of steps to follow when performing this type of analysis, using tools from this toolset as well as others available in the Spatial Analyst toolbox. Since each approach is based on different assumptions, the meaning of the numbers and the analysis techniques are specific to the approach. Which one to select will depend on the problem you are addressing.
Use the Weighted Overlay and Weighted Sum tools to perform the most general approach to reclassifying and weighting multiple input rasters in Overlay analysis. The Fuzzy Overlay and Fuzzy Membership tools employ fuzzy logic as a mechanism to address inherent inaccuracies in attributes and in the geometry of spatial datasets.
The Locate Regions tool allows you to identify the best locations or regions within the combined surface that meet your specific needs. You can control the total area desired, the number of regions that area should be distributed between, the shape of the regions, and how close or how far the regions can be from each other.
The following table lists the available tools and provides a brief description of each:
Tool |
Description |
Transforms the input raster into a 0 to 1 scale, indicating the strength of a membership in a set, based on a specified fuzzification algorithm. |
Combines fuzzy membership raster data together based on selected overlay type. |
Identifies the best regions, or groups of contiguous cells, from an input utility (suitability) raster that satisfy a specified evaluation criterion and that meet identified shape, size, number, and interregion distance constraints. |
Combines multiple rasters using a selected multicriteria overlay method, with importance weights applied according to the method. |
Overlays several rasters using a common measurement scale and weights each according to its importance. |
Overlays several rasters, multiplying each by their given weight and summing them together. |
