An overview of the Zonal toolset
Available with Spatial Analyst license.
The Zonal tools allow you to perform analysis when the output is a result of computations performed on all cells that belong to each input zone. A zone can be defined as a single area of a particular value, but it can also be composed of multiple disconnected elements, or regions, all having the same value. Zones can be defined by raster or feature datasets. Rasters must be of integer type, and features must have an integer or string attribute field.
Some zonal tools quantify certain properties of the geometry, or shape, of the zone input and do not require any other inputs. Other zonal tools use the zone input to define the locations for which other parameters will be calculated, such as statistics, areas, or value frequencies. There is also a zonal tool that is used to fill specified zones with the minimum value found along the zone boundary.
The applications for zonal tools are divided into the following categories:
Zonal tool application category
Tool(s)
Tools that work on zone shapes.
Zonal Geometry
Zonal Geometry As Table
Tools that work on zone attributes.
Zonal Characterization
Zonal Statistics
Zonal Statistics as Table
Tool that determines the area of classes within zones.
Tabulate Area
Tool that determines the frequency distribution of values of one input raster within zones of another.
Zonal Histogram
Tool that fills specified zones.
Zonal Fill
The following table lists the available tools and provides a brief description of each:
Tool
Tabulate Area
Calculates cross-tabulated areas between two datasets and outputs a table.
Summarizes the values of multiple rasters within the zones of another dataset and reports the results as a table.
Zonal Fill
Fills zones using the minimum cell value from a weight raster along the zone boundary.
Zonal Geometry
Calculates the specified geometry measure (area, perimeter, thickness, or the characteristics of an ellipse) for each zone in a dataset.
Calculates the geometry measures (area, perimeter, thickness, and the characteristics of an ellipse) for each zone in a dataset and reports the results as a table.
Zonal Histogram
Creates a table and a histogram graph that show the frequency distribution of cell values on the value input for each unique zone.
Zonal Statistics
Summarizes the values of a raster within the zones of another dataset.
Summarizes the values of a raster within the zones of another dataset and reports the results as a table.
Tools of the Zonal toolset
