Zonal Geometry (Spatial Analyst Tools)
Summary
Calculates the specified geometry measure (area, perimeter, thickness, or the characteristics of an ellipse) for each zone in a dataset.
Learn more about how Zonal Geometry works
Illustration
Zonal Geometry tool illustration
OutRas = ZonalGeometry(InRas1,"VALUE","AREA")
Usage
  • A zone is defined as all areas in the input that have the same value. The areas do not have to be contiguous. Both rasters and features can be used for the zone input.
  • The Output cell size parameter can be defined by a numeric value or obtained from an existing raster dataset. If the cell size hasn't been explicitly specified as the parameter value, it is derived from the Cell Size environment if it has been specified. If the parameter cell size or the environment cell size have not been specified, the default output cell size is determined based on the type of input dataset as follows:
    • If the input dataset is a raster, the cell size of the dataset is used.
    • If the input dataset is a feature and the Snap Raster environment has been set, the cell size of the snap raster is used. If no snap raster is set, the cell size is calculated from the shorter of the width or height of the extent divided by 250 in which the extent is in the output coordinate system specified in the environment.
  • If the cell size is specified using a numeric value, the tool will use it directly for the output raster.
    If the cell size is specified using a raster dataset, the parameter will show the path of the raster dataset instead of the cell size value. The cell size of that raster dataset will be used directly in the analysis, provided the spatial reference of the dataset is the same as the output spatial reference. If the spatial reference of the dataset is different than the output spatial reference, it will be projected based on the specified Cell Size Projection Method value.
  • If the Input Raster or Feature Zone Data value has overlapping polygons, the zonal analysis will not be performed for each individual polygon. Since the feature input is converted to a raster, each location can have only one value.
    An alternative method is to process the zonal operation iteratively for each of the polygon zones and collate the results.
  • When specifying the Input Raster or Feature Zone Data parameter value, the default zone field will be the first available integer or text field. If no other valid fields exist, the ObjectID field (for example, OID or FID) will be the default.
  • The data type of the output raster for each of the geometry types will be floating point.
  • If a particular zone consists of only one cell or if the zone is a single square block of cells, the orientation of the ellipse (which, in this case, is a circle) is set to 90 degrees.
  • When the output raster format is .crf, this tool supports the Pyramid raster storage environment. Pyramids will be created in the output by default. For any other output format, this environment is not supported, and pyramids will not be created.
  • See Analysis environments and Spatial Analyst for additional details on the geoprocessing environments that apply to this tool.
Parameters
Label Explanation Data type
The dataset that defines the zones.
The zones can be defined by an integer raster or a feature layer.
Raster Layer; Feature Layer
Zone Field
The field that contains the values that define each zone.
It must be an integer field of the zone dataset.
Field
Geometry Type
(Optional)
Specifies the geometry type that will be calculated.
  • Area—The area for each zone will be calculated.
  • Perimeter—The perimeter for each zone will be calculated.
  • Thickness—The deepest (or thickest) point within the zone from its surrounding cells will be calculated.
  • Centroid—The centroids of each zone will be calculated.
String
Output Cell Size
(Optional)
The cell size of the output raster that will be created.
This parameter can be defined by a numeric value or obtained from an existing raster dataset. If the cell size hasn't been explicitly specified as the parameter value, the environment cell size value will be used if specified; otherwise, additional rules will be used to calculate it from the other inputs. See the usage section for more detail.
Analysis Cell Size
Return value
Output Raster
The output zonal geometry raster.
Raster
Environments
Auto Commit, Cell Size, Cell Size Projection Method, Compression, Current Workspace, Extent, Geographic Transformations, Mask, Output CONFIG Keyword, Output Coordinate System, Parallel Processing Factor, Pyramid, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires Spatial Analyst
  • Standard: Requires Spatial Analyst
  • Advanced: Requires Spatial Analyst
