Zonal Statistics as Table (Spatial Analyst Tools)
Summary
Summarizes the values of a raster within the zones of another dataset and reports the results as a table.
Learn more about how the zonal statistics tools work
Illustration
Zonal Statistics as Table tool illustration
ZonalStatisticsAsTable(ZoneRas, "Value", ValRas, OutTable, "DATA", "MIN_MAX_MEAN")
Usage
  • A zone is defined as all areas in the input that have the same value. The areas do not have to be contiguous. Both rasters and features can be used for the zone input.
  • If the Input Raster or Feature Zone Data parameter value (in_zone_data in Python) is a raster, it must be an integer raster.
  • If the Input Raster or Feature Zone Data parameter value is a feature, it will be converted to a raster internally using the cell size and cell alignment from the Input Value raster (in_value_raster in Python) parameter.
  • If the cell size, cell alignment, or spatial reference of the Input Raster or Feature Zone Data and Input Value Raster parameter values is different, the Input Value Raster value will be used as the Cell Size, the Snap Raster, and the Output Coordinate System internally. Any of these cases will cause an internal resampling before the zonal operation is performed.
    When the zone and value inputs are both rasters of the same cell size and the cells are aligned, they will be used directly in the tool and will not be resampled internally during tool processing.
  • If the Input Raster or Feature Zone Data parameter value is a feature, for any of the zone features that do not overlap any cell centers of the value raster, those zones will not be converted to the internal zone raster. As a result, those zones will not be represented in the output. You can manage this by determining an appropriate value for the Cell Size environment that will preserve the desired level of detail of the feature zones, and specify it in the analysis environment.
  • If the Input Raster or Feature Zone Data value is a point feature, more than one point may be contained in any particular cell of the value input raster. For such cells, the zone value is determined by the point with the lowest ObjectID field (for example, OID or FID).
  • If the Input Raster or Feature Zone Data parameter value has overlapping features, the zonal analysis will be performed for each individual feature.
  • When specifying the Input Raster or Feature Zone Data parameter value, the default zone field will be the first available integer or text field. If no other valid fields exist, the ObjectID field (for example, OID or FID) will be the default.
  • The supported statistics type depends on the data type of the Input Value Raster value, and the statistics calculation type specified by the Calculate Circular Statistics parameter.
    If the data type is integer, the arithmetic statistics calculation supports the Mean, Majority, Majority count, Majority percentage, Maximum, Median, Minimum, Minority, Minority count, Minority percentage, Percentile, Range, Standard deviation, Sum, and Variety options. The circular statistics calculation supports the Mean, Majority, Minority, Standard deviation, and Variety options.
    If the data type is float, the arithmetic statistics calculation supports the Mean, Maximum, Median, Minimum, Percentile, Range, Standard deviation, and Sum options. The circular statistics calculation supports the Mean and Standard deviation options.
  • For majority and minority calculations, when there is a tie, the output will be the lowest of the tied values.
  • To calculate circular statistics, check the Calculate Circular Statistics parameter (circular_calculation = "CIRCULAR" in Python), and specify a value for the Circular Wrap Value parameter (circular_wrap_value in Python).
  • Supported multidimensional raster dataset types include multidimensional raster layer, mosaic, image service, and Esri CRF.
  • A field or series of fields will be created in the output table depending on the Statistics Type parameter setting (statisticType in Python).
    The name of the field is the same as the statistics type for arithmetic statistics calculation. This is the default.
    However, for circular statistics the name of the field will be prefaced with C_, followed by the specified statistic. For example, the field name will be Median for the arithmetic median statistic and C_Median for the circular median statistic.
  • The data type for each value of the items in the output table depends on the zonal calculation being performed. See How the zonal statistics tools work for the specific behavior of a statistic.
  • The number of rows in the output table is the number of zones. If the summary statistics for an entire zone is NoData, there will be no record for that particular zone in the output table.
  • By default, this tool will use up to 80 percent of all multicore processors if available.
    For a very large number of zones, use fewer number of cores for processing. To use a different number of cores, use the Parallel Processing Factor environment setting.
  • See Analysis environments and Spatial Analyst for additional details on the geoprocessing environments that apply to this tool.
Parameters
Label Explanation Data type
The dataset that defines the zones.
The zones can be defined by an integer raster or a feature layer.
Raster Layer; Feature Layer
Zone Field
The field that contains the values that define each zone.
It can be an integer or a string field of the zone dataset.
Field
Input Value Raster
The raster that contains the values for which a statistic will be calculated.
Raster Layer
Output Table
The output table that will contain the summary of the values in each zone.
The format of the table will be determined by the output location and path. By default, the output will be a geodatabase table if in a geodatabase workspace, and a dBASE table if in a file workspace.
Table
Ignore NoData in Calculations
(Optional)
Specifies whether NoData values in the value input will be ignored in the results of the zone that they fall within.
  • Checked—Within any particular zone, only cells that have a value in the input value raster will be used in determining the output value for that zone. NoData cells in the value raster will be ignored in the statistic calculation. This is the default.
  • Unchecked—Within any particular zone, if NoData cells exist in the value raster, they will not be ignored and their existence indicates that there is insufficient information to perform statistical calculations for all the cells in that zone. Consequently, the entire zone will receive the NoData value.
Boolean
Statistics Type
(Optional)
Specifies the statistic type that will be calculated.
  • All—All of the statistics will be calculated. This is the default.
  • Mean—The average of all cells in the value raster that belong to the same zone as the output cell will be calculated.
  • Majority—The value that occurs most often for all cells in the value raster that belong to the same zone as the output cell will be calculated.
  • Majority count—The frequency of all cells that contain the majority value in the value raster that belong to the same zone as the output cell will be calculated.
  • Majority percentage—The percentage of cells that contain the majority value in the value raster that belong to the same zone as the output cell will be calculated.
  • Maximum—The largest value of all cells in the value raster that belong to the same zone as the output cell will be calculated.
  • Median—The median value of all cells in the value raster that belong to the same zone as the output cell will be calculated.
  • Minimum—The smallest value of all cells in the value raster that belong to the same zone as the output cell will be calculated.
  • Minority—The value that occurs least often for all cells in the value raster that belong to the same zone as the output cell will be calculated.
  • Minority count—The frequency of all cells that contain the minority value in the value raster that belong to the same zone as the output cell will be calculated.
  • Minority percentage—The percentage of cells that contain the minority value in the value raster that belong to the same zone as the output cell will be calculated.
  • Percentile—The percentile of all cells in the value raster that belong to the same zone as the output cell will be calculated. The 90th percentile is calculated by default. You can specify other values (from 0 to 100) using the Percentile Values parameter.
  • Range—The difference between the largest and smallest value of all cells in the value raster that belong to the same zone as the output cell will be calculated.
  • Standard deviation—The standard deviation of all cells in the value raster that belong to the same zone as the output cell will be calculated.
  • Sum—The total value of all cells in the value raster that belong to the same zone as the output cell will be calculated.
  • Variety—The number of unique values for all cells in the value raster that belong to the same zone as the output cell will be calculated.
  • Minimum and Maximum—Both the minimum and maximum statistics will be calculated.
  • Mean and Standard deviation—Both the mean and standard deviation statistics will be calculated.
  • Minimum, Maximum, and Mean—The minimum, maximum, and mean statistics will be calculated.
  • Majority value, count, and percentage—The majority value, count, and percentage statistics will be calculated.
  • Minority value, count, and percentage—The minority value, count, and percentage statistics will be calculated.
String
Process as Multidimensional
(Optional)
Specifies how the input rasters will be calculated if they are multidimensional.
  • Checked—Statistics will be calculated for all dimensions of the input multidimensional dataset.
  • Unchecked—Statistics will be calculated from the current slice of the input multidimensional dataset. This is the default.
Boolean
Percentile Values
(Optional)
The percentile that will be calculated. The default is 90, indicating the 90th percentile.
The values can range from 0 to 100. The 0th percentile is essentially equivalent to the minimum statistic, and the 100th percentile is equivalent to maximum. A value of 50 will produce essentially the same result as the median statistic.
This parameter is only available if the Statistics type parameter is set to Percentile or All.
Double
Percentile Interpolation Type
(Optional)
Specifies the method of interpolation that will be used when the percentile value falls between two cell values from the input value raster.
  • Auto-detect—If the input value raster is of integer pixel type, the Nearest method will be used. If the input value raster is of floating point pixel type, the Linear method will be used. This is the default.
  • Nearest—The nearest available value to the desired percentile will be used.
  • Linear—The weighted average of the two surrounding values from the desired percentile will be used.
String
(Optional)
Specifies how the input raster will be processed for circular data.
  • Checked—The statistics for angles or other cyclic quantities, such as compass direction in degrees, daytimes, and fractional parts of real numbers, will be calculated.
  • Unchecked—Ordinary linear statistics will be calculated. This is the default.
Boolean
Circular Wrap Value
(Optional)
The value that will be used to round a linear value to the range of a given circular statistic. It must be a positive integer or a floating-point value. The default value is 360 degrees.
This parameter is only supported if the Calculate Circular Statistics parameter is checked.
Double
Output Join Layer
(Optional)
The output layer that will be created by joining the output table to the input zone data.
Environments
Auto Commit, Cell Size, Cell Size Projection Method, Compression, Current Workspace, Extent, Geographic Transformations, Mask, Output CONFIG Keyword, Output Coordinate System, Parallel Processing Factor, Maintain fully qualified field names, Scratch Workspace, Snap Raster, Tile Size, Transfer Field Domain Descriptions
Licensing information
  • Basic: Requires Spatial Analyst or Image Analyst
  • Standard: Requires Spatial Analyst or Image Analyst
  • Advanced: Requires Spatial Analyst or Image Analyst
