Contour with Barriers (Spatial Analyst Tools)
Summary
Creates contours from a raster surface. The inclusion of barrier features allows you to independently generate contours on either side of a barrier.
Usage
  • The current version of Contour with Barriers only supports polyline output. If the polygon output option is used it will be ignored and polyline output will be created.
  • Smoother but less accurate contours can be obtained by preprocessing the input raster using the Focal Statistics tool with the Mean option or the Filter tool with the Low option.
  • Contours will extend into the raster's NoData cell by a distance of half the raster's cell size. This will mean that the contours will be generated over single NoData cells. However, a 3-cell-by-3-cell area of NoData will only have the contours extending into this area by half the cell size distance.
  • The Type field in the output contour feature class can have values such as: 1 for contours, 2 for indexed contours, and 3 for explicit contours.
  • An indexed contour interval can be used to generate additional contours and their Type value will be coded as 2 in the output feature class.
  • A base contour is used, for example, when you want to create contours every 15 meters, starting at 10 meters. Here, 10 would be used for the base contour, and 15 would be the contour interval. The values to be contoured would be 10, 25, 40, 55, and so on.
  • Specifying a base contour does not prevent contours from being created above or below that value.
  • A text file containing contour value specifications can include the following:
    • Any line that starts with a non-numeric value will be ignored and treated as a comment line.
    • A line with a single value will be treated as an explicit contour value.
    • A line with three values will be treated as base, contour interval, and indexed contour.
    • A line with four values will treated as from, to, by, and indexed contours.
    For example, if a raster has a minimum value of 102 and a maximum of 500, then a text file with:
    # contour values and ranges
    122.75
    485 500 5 12
    4 100 99
    will produce contours at:
    122.75
    104, 204, 304, 404
    103, 202, 301, 400, 499
    485, 490, 495, 500
    497
  • If there are cell values of the raster within a barrier polygon feature the contour lines will be split at the barrier. If the cell values within the polygon feature are to be ignored, change those cell values to NoData.
  • If the input raster surface is very large or many output features are requested, a large number of temporary files will be created in the operating system's temporary file location. If any problems are encountered as a result of this do one of the following:
    • Increase the available disk space for temporary files.
    • Reduce the number of contours specified, or split the contour range up and process each group separately, and combine the results from each range into a final result.
    • Process the input data in sections (tiles), and merge the individual results into one dataset.
  • See Analysis environments and Spatial Analyst for additional details on the geoprocessing environments that apply to this tool.
Parameters
Label Explanation Data type
Input Raster
The input surface raster.
Raster Layer; Raster Dataset; Mosaic Layer; Mosaic Dataset
Output Contour Features
The output contour features.
Feature Class
Input Barrier Features
(Optional)
The input barrier features.
The features can be polyline or polygon type.
Feature Layer
Type of Contours
(Optional)
The type of contour to create.
The current version of this tool only supports polyline output. If the polygon output option is used, it will be ignored and polyline output will be created.
  • Polylines—The contour or isoline representation of the input raster.
  • Polygons—Closed polygons representing the contours.
String
File Containing Contour Value Specifications
(Optional)
The base contour, contour interval, indexed contour interval, and explicit contour values can also be specified via a text file.
File
Enter Explicit Contour Values Only
(Optional)
Only explicit contour values are used. Base contour, contour interval, and indexed contour intervals are not specified.
  • Checked—Only explicit contour values are specified.
  • Unchecked—The default, contour interval must be specified.
Boolean
Base Contour
(Optional)
The base contour value.
Contours are generated above and below this value as needed to cover the entire value range of the input raster. The default is zero.
Double
Contour Interval
(Optional)
The interval, or distance, between contour lines.
This can be any positive number.
Double
Indexed Contour Interval
(Optional)
Contours will also be generated for this interval and will be flagged accordingly in the output feature class.
Double
(Optional)
Explicit values at which to create contours.
Double
Factor Applied to Raster Z-values
(Optional)
The unit conversion factor used when generating contours. The default value is 1.
The contour lines are generated based on the z-values in the input raster, which are often measured in units of meters or feet. With the default value of 1, the contours will be in the same units as the z-values of the input raster. To create contours in a unit other than that of the z-values, set an appropriate value for the z-factor. It is not necessary to have the ground x,y and surface z-units be consistent for this tool.
For example, if the elevation values in the input raster are in feet, but you want the contours to be generated based on units of meters, set the z-factor to 0.3048 (1 foot = 0.3048 meter).
Double
Environments
Auto Commit, Current Workspace, Default Output Z Value, Extent, Geographic Transformations, M Resolution, M Tolerance, Output CONFIG Keyword, Output Coordinate System, Output has M values, Output has Z values, Output M Domain, Output XY Domain, Output Z Domain, Scratch Workspace, XY Resolution, XY Tolerance, Z Resolution, Z Tolerance
Licensing information
  • Basic: Requires Spatial Analyst or 3D Analyst
  • Standard: Requires Spatial Analyst or 3D Analyst
  • Advanced: Requires Spatial Analyst or 3D Analyst
