Cost Path (Spatial Analyst Tools)
Summary
Calculates the least-cost path from a source to a destination.
Legacy:
This tool is deprecated and will be removed in a future release.
The Optimal Path As Raster tool provides enhanced functionality or performance.
Learn more about creating the least cost path
Usage
  • The Cost Path tool produces an output raster that records the least-cost path or paths from selected locations to the closest source cell defined within the accumulative cost surface, in terms of cost distance.
  • One or more of the weighted cost tools (Cost Distance, Cost Back Link, or Cost Allocation) are generally required to run prior to running Cost Path to create the input cost distance and back link rasters. These are mandatory input rasters to Cost Path.
  • Each least-cost path is assigned a value when encountered in the scanning process. The ending cell on the original source raster (from which the cost distance and back link were derived) of a cost path receives one, the first path receives three, the second four, and so on. The value two is reserved for the merged portion of paths that have portions of a common cost path.
  • When the input destination data is a raster, the set of destination cells consists of all cells in the input raster or feature destination data that have valid values. Cells that have NoData values are not included in the source set. The value zero is considered a legitimate destination. A destination raster can be easily created using the extraction tools.
  • When the source input is a feature, the first valid available field will be used by default. If no valid fields exist, the ObjectID field (for example, OID or FID, depending on the type of feature input) will be used.
  • When using polygon feature data for the input feature destinations, care must be taken with how the output cell size is handled when it is coarse relative to the detail present in the input. In the internal rasterization process that employs the Polygon to Raster tool, the default setting of Cell assignment type will be Cell center. This means that data not located at the center of the cell will not be included in the intermediate rasterized destination output, and so will not be represented in the distance calculations. For example, if your destinations are a series of small polygons, such as building footprints, that are small relative to the output cell size, it is possible that only a few of them will fall under the centers of the output raster cells, seemingly causing most of the others to be lost in the analysis.
    To avoid this situation, as an intermediate step, you can rasterize the input features directly with the Feature to Raster tool and set the Field parameter. Then use the resulting output as input to the particular distance tool you want to use. Alternatively, you can select a small cell size to capture the appropriate amount of detail from the input features.
  • When multiple paths merge and follow the remaining distance back to a source on the same route, the segment where the two paths travel together is assigned the value 2. The merged portion of the path cannot be assigned the value of one of the paths, since the merged portion belongs to both routes.
    Map of merged paths
    Example of Each zone option with merged paths
  • Cost Path will ignore the Cell size environment setting and use the cell size of the Input cost backlink raster for the output raster. The pattern of the back link raster would be seriously altered if it were resampled to a different resolution. To avoid any confusion, the cell size should not be set when using this tool.
  • Cost Path can be used to determine the flow path based on D8 flow direction. To use Cost Path in this way, use a D8 flow direction raster as input for the Input cost backlink raster. You also need to supply an Input cost distance raster; the Input cost distance raster is not used to determine the path. Whether you use a constant raster or a digital elevation model (DEM), your path will be the same; only an attribute value on your path will vary. See the Flow Direction tool for more information on D8 flow direction rasters.
  • When the input destination data is feature, it must contain at least one valid field.
  • When the output raster format is .crf, this tool supports the Pyramid raster storage environment. Pyramids will be created in the output by default. For any other output format, this environment is not supported, and pyramids will not be created.
  • See Analysis environments and Spatial Analyst for additional details on the geoprocessing environments that apply to this tool.
Parameters
Label Explanation Data type
Input raster or feature destination data
A raster or feature dataset that identifies those cells from which the least-cost path is determined to the least costly source.
If the input is a raster, the input consists of cells that have valid values (zero is a valid value), and the remaining cells must be assigned NoData.
Raster Layer; Feature Layer
The name of a cost distance raster to be used to determine the least-cost path from the destination locations to a source.
The cost distance raster is usually created with the Cost Distance, Cost Allocation or Cost Back Link tools. The cost distance raster stores, for each cell, the minimum accumulative cost distance over a cost surface from each cell to a set of source cells.
Raster Layer
The name of a cost back link raster used to determine the path to return to a source via the least-cost path.
For each cell in the back link raster, a value identifies the neighbor that is the next cell on the least accumulative cost path from the cell to a single source cell or set of source cells.
Raster Layer
Path type
(Optional)
A keyword defining the manner in which the values and zones on the input destination data will be interpreted in the cost path calculations.
  • Each cell—For each cell with valid values on the input destination data, a least-cost path is determined and saved on the output raster. With this option, each cell of the input destination data is treated separately, and a least-cost path is determined for each from cell. This is default.
  • Each zone—For each zone on the input destination data, a least-cost path is determined and saved on the output raster. With this option, the least-cost path for each zone begins at the cell with the lowest cost distance weighting in the zone.
  • Best single—For all cells on the input destination data, the least-cost path is derived from the cell with the minimum of the least-cost paths to source cells.
String
Destination field
(Optional)
The field used to obtain values for the destination locations.
Input feature data must contain at least one valid field.
Field
Force flow direction convention for backlink raster
(Optional)
Specifies whether the input backlink raster will be treated as a flow direction raster. Flow direction rasters can have integer values that range from 0-255.
  • Checked—The Input cost backlink raster parameter value will be treated as a flow direction raster. This is necessary if the flow direction raster has a maximum value of 8 or less.
  • Unchecked—The Input cost backlink raster parameter value will be interpreted based on the range of values and whether it is integer or float. For a value range of 0-8, the value will be treated as a backlink raster. For values 0-255 and integer, the value will be treated as a flow direction raster. For a value range of 0-360 and floating point, the value will be treated as a back direction raster. This is default.
Boolean
Return value
Output raster
The output cost path raster.
The output raster is of integer type.
Raster
Environments
Auto Commit, Compression, Current Workspace, Output CONFIG Keyword, Pyramid, Scratch Workspace, Tile Size
Licensing information
  • Basic: Requires Spatial Analyst
  • Standard: Requires Spatial Analyst
  • Advanced: Requires Spatial Analyst
