Dimensional Moving Statistics (Spatial Analyst Tools)
Summary
Calculates statistics over a moving window on multidimensional data along a specified dimension.
Usage
  • Moving statistics can also be called moving window statistics, rolling statistics, or running statistics. A predefined window around each dimension value is used to calculate various statistics before moving to the next. The Backward Window and Forward Window parameters allow you to define window sizes on both sides of the dimension.
  • The input raster can only be a multidimensional raster in Cloud Raster Format (.crf file).
  • Only one dimension will be processed by this tool. By default, the first dimension other than x,y will be used as the processing dimension.
  • The Circular Mean statistics type calculates the mean for angles or other cyclic quantities, such as compass direction in degrees. When this option is selected, the Circular Wrap Value parameter becomes available. Use this parameter to designate a value to wrap around to calculate the circular mean. For example, for angle calculation, the circular wrap value should be 360 degrees, which means the value 360 will be wrapped to 0, and the value 370 will be wrapped to 10. Another use is for time calculations of months in a year, in which case the circular wrap value should be 12. In this case, an input value of 13 will be wrapped to 1.
  • If the input multidimensional raster is integer, the valid options for Statistics Type are Mean, Circular Mean, Majority, Maximum, Median, Minimum, and Percentile. If the input raster is float, Majority is not available.
  • If the input raster is integer, the output raster will be integer for the Majority, Maximum, and Minimum options. The output will be float for Mean, Circular Mean, Median, and Percentile.
    If the input raster is of float type, the output will be float for all of the available statistics types.
  • For the Majority option, when there is a tie, the output will be the lowest of the tied values.
  • See Analysis environments and Spatial Analyst for additional details on the geoprocessing environments that apply to this tool.
Parameters
Label Explanation Data type
Input Multidimensional Raster
Raster Layer
Dimension
(Optional)
The name of the dimension along which the window will move.
The default value is the first dimension other than x,y found in the input multidimensional raster.
String
Backward Window
(Optional)
The value of how many slices before or above to be included in the defined window. The value must be a positive integer from 1 to 100. The default value is 1.
The unit of this parameter is slice.
Long
Forward Window
(Optional)
The value of how many slices after or below to be included in the defined window. The value must be a positive integer from 1 to 100. The default value is 1.
Long
NoData Handling
(Optional)
Specifies how NoData values will be handled by the statistic calculation.
  • Data—NoData values within the defined window will be ignored when calculating the selected statistic. Only cells within the defined window that have data values will be used in determining the output value. If the processing cell is NoData, that cell will receive a value in the output raster, provided at least one cell within the defined window has a valid value. This is the default.
  • NoData—Output values will be NoData if any NoData values are found within the defined window. The presence of a NoData value indicates that there is insufficient information to determine the statistic value for the defined window.
  • Fill NoData—NoData cell values will be replaced in the output using the selected statistic calculated from the values within the defined window. Input cells that have data values will remain the same in the output.
String
Statistics Type
(Optional)
Specifies the statistics type to be calculated.
  • Mean—The mean (average value) of the cells in the defined window will be calculated. This is the default.
  • Circular Mean—The mean for angles or other cyclic quantities—such as compass direction in degrees, daytimes, or fractional parts of real numbers—will be calculated. When this statistics type is specified, the Circular Wrap Value parameter becomes available. Use this parameter to designate a wrap value.
  • Majority—The majority (value that occurs most often) of the cells in the defined window will be identified.
  • Maximum—The maximum (largest value) of the cells in the defined window will be identified.
  • Median—The median of the cells in the defined window will be identified.
  • Minimum—The minimum (smallest value) of the cells in the defined window will be identified.
  • Percentile—A percentile of the cells in the defined window will be calculated. The 90th percentile is calculated by default. When this statistics type is specified, the Percentile Value and Percentile Interpolation Type parameters become available. Use these new parameters to designate the percentile to calculate and choose the interpolation type to use, respectively.
String
Percentile Value
(Optional)
The percentile value that will be calculated. The default is 90, for the 90th percentile.
The value can range from 0 through 100. The 0th percentile is essentially equivalent to the minimum statistic, and the 100th percentile is equivalent to the maximum statistic. A value of 50 will produce essentially the same result as the median statistic.
This parameter is only supported if the Statistics Type parameter is set to Percentile.
Double
(Optional)
Specifies the method of interpolation that will be used when the percentile value falls between two cell values.
This parameter is only supported if the Statistics Type parameter is set to Median or Percentile.
  • Auto-detect—If the input raster is of integer pixel type, the Nearest method will be used. If the input raster is of float pixel type, the Linear method will be used. This is the default.
  • Nearest—The nearest available value to the percentile will be used. In this case, the output pixel type will be the same as that of the input raster.
  • Linear—The weighted average of the two surrounding values from the percentile will be used. In this case, the output pixel type will be floating point.
String
Circular Wrap Value
(Optional)
The value that will be used to convert a linear value to the range of a given circular mean. Its value must be positive. The default value is 360 degrees.
This parameter is only supported if the Statistics Type parameter is set to Circular Mean.
Double
Derived output
Raster Function Arguments JSON
The arguments of the function. This output is for internal use only.
String
Return value
Output Multidimensional Raster
The output raster can only be a multidimensional raster in Cloud Raster Format (.crf file).
Raster
Environments
Auto Commit, Cell Size, Cell Size Projection Method, Compression, Current Workspace, Extent, Geographic Transformations, Mask, Output CONFIG Keyword, Output Coordinate System, Parallel Processing Factor, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires Spatial Analyst or Image Analyst
  • Standard: Requires Spatial Analyst or Image Analyst
  • Advanced: Requires Spatial Analyst or Image Analyst
