Geodesic Flow Direction (Spatial Analyst Tools)
Summary
Creates a raster of flow direction from each cell to its downslope neighbor, or neighbors, using a geodesic method.
Illustration
Geodesic Flow Direction tool illustration
Flow_Dir = GeodesicFlowDirection(Elev_Ras, #, #, D8)
Usage
  • The tool calculates the direction of flow out of each cell accounting for the planet’s curved ellipsoidal shape based on three flow modeling algorithms: D8, Multiple Flow Direction (MFD), and D-Infinity (DINF)
  • When the Flow Direction Type (flow_direction_type in Python) parameter value is set to the D8 option, the output is an integer raster that ranges in value from 1 to 255.
    This method models flow direction from each cell to its steepest downslope neighbor. The downslope to each neighbor will be calculated as the ratio between the elevation drop and the geodesic distance between cell centers.
    For each of the 8 cardinal directions, the flow direction value is the following:
    Flow Direction values
    Other considerations when using this flow direction method include:
    • A target cell may have a lower elevation value than that of its neighbors.
      When the elevation value of the target cell is lower than that of its neighbors, the cell value is replaced by the elevation value of the lowest neighbor (or neighbors in case multiple share the same lowest value).
      When the elevation drop is the same in multiple directions and the cell is part of a sink, the flow direction value will be the sum of the directions. For example, if the change in z-value is the same both to the right (flow direction = 1) and down (flow direction = 4), the flow direction for that cell will be calculated as 1 + 4 = 5. Cells with undefined flow direction can be flagged as sinks using the Sink tool.
      When the elevation drop is the same in multiple directions and the cell is not part of a sink, the flow direction will be assigned with a lookup table defining the most likely direction. See Greenlee (1987).
    • The output D8 drop raster is calculated as the difference in z-value divided by the path length between the cell centers, expressed in percentages. For adjacent cells, this is analogous to the percent slope between cells. Across a flat area, the distance becomes the distance to the nearest cell of lower elevation. The result is a map of percent rise in the path of steepest descent from each cell.
  • The MFD algorithm, described by Qin et al. (2007), partitions flow from a cell to all downslope neighbors. A flow-partition exponent will be created from an adaptive approach based on local terrain conditions and is used to determine the fraction of flow draining to all downslope neighbors.
    The MFD flow direction type only supports the creation of an output flow direction raster in Cloud Raster Format (CRF), such as flowdir1.crf, in a folder workspace.
    The MFD flow direction output when added to a map only displays the D8 flow directions. As MFD flow directions have potentially multiple values related to each cell (each value corresponds to the proportion of flow to each downslope neighbor), it is not easily visualized. However, an MFD flow direction output raster is an input recognized by the Flow Accumulation tool that will use the MFD flow directions to proportion and accumulate flow from each cell to all downslope neighbors.
  • The DINF flow method, described by Tarboton (1997), determines flow direction as the steepest downward slope on eight triangular facets formed in a 3 by 3 cell window centered on the cell of interest. Flow direction output is a floating point raster represented as a single angle in degrees counterclockwise from 0 (due east) to 360 (again due east).
  • With the Force all edge cells to flow outward parameter unchecked (force_flow = "NORMAL" in Python), which is the default setting, a cell at the edge of the surface raster will flow toward the inner cell with the steepest drop in z-value. If the drop is less than or equal to zero, the cell will flow out of the surface raster.
  • When the input raster has rectangular cells, it will be processed so that the output raster cells will be square with sides equal to the average of the rectangular length and width.
  • This tool supports parallel processing. If your computer has multiple processors or processors with multiple cores, better performance may be achieved, particularly on larger datasets. The Parallel processing with Spatial Analyst help topic includes details about this capability and how to configure it.
    When using parallel processing, temporary data will be written to manage the data chunks being processed. The default temp folder location will be on your local C: drive. You can control the location of this folder by setting up a system environment variable named TempFolders and specifying the path to a folder to use (for example, E:\RasterCache). If you have administrator privileges on your machine, you can also use a registry key (for example, [HKEY_CURRENT_USER\SOFTWARE\ESRI\ArcGISPro\Raster]).
    By default, this tool will use 50 percent of the available cores. If the input data is smaller than 5,000-by-5,000 cells in size, fewer cores may be used. You can control the number of cores the tool uses with the Parallel processing factor environment.
  • When the output raster format is .crf, this tool supports the Pyramid raster storage environment. Pyramids will be created in the output by default. For any other output format, this environment is not supported, and pyramids will not be created.
  • See Analysis environments and Spatial Analyst for additional details on the geoprocessing environments that apply to this tool.
Parameters
Label Explanation Data type
Input Surface Raster
The input raster representing a continuous surface.
Raster Layer
Force All Edge Cells to Flow Outward
(Optional)
Specifies whether edge cells will always flow outward or follow normal flow rules.
  • Checked—All cells at the edge of the surface raster will flow outward from the surface raster.
  • Unchecked—If the maximum drop on the inside of an edge cell is greater than zero, the flow direction will be determined as usual; otherwise, the flow direction will be toward the edge. Cells that should flow from the edge of the surface raster inward will do so. This is the default.
Boolean
Output Drop Raster
(Optional)
An optional output drop raster.
The drop raster returns the ratio of the maximum change in elevation from each cell along the direction of flow to the path length between centers of cells, expressed in percentages.
This output is of floating-point type.
Raster Dataset
Flow Direction Type
(Optional)
Specifies the type of flow method that will be used when computing geodesic flow directions.
  • D8—Flow direction will be determined by the D8 method. This method assigns flow direction to the steepest downslope neighbor. This is the default.
  • MFD—Flow direction will be based on the MFD flow method. Flow direction will be partitioned across downslope neighbors according to an adaptive partition exponent.
  • DINF—Flow direction will be based on the DINF flow method. This method assigns flow direction to the steepest slope of a triangular facet.
String
Return value
Output Flow Direction Raster
The output raster that shows the geodesic flow direction from each cell to its downslope neighbors or neighbors using the specified method.
This output will be of integer type.
Raster
Environments
Auto Commit, Cell Size, Cell Size Projection Method, Compression, Current Workspace, Extent, Geographic Transformations, Mask, Output CONFIG Keyword, Output Coordinate System, Parallel Processing Factor, Pyramid, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires Spatial Analyst
  • Standard: Requires Spatial Analyst
  • Advanced: Requires Spatial Analyst
References
  • Greenlee, D. D. 1987. "Raster and Vector Processing for Scanned Linework." Photogrammetric Engineering and Remote Sensing 53 (10): 1383–1387.
  • Qin, C., Zhu, A. X., Pei, T., Li, B., Zhou, C., & Yang, L. 2007. "An adaptive approach to selecting a flow partition exponent for a multiple flow direction algorithm." International Journal of Geographical Information Science 21(4): 443-458.
  • Tarboton, D. G. 1997. "A new method for the determination of flow directions and upslope areas in grid digital elevation models." Water Resources Research 33(2): 309-319.
