Iso Cluster Unsupervised Classification (Spatial Analyst Tools)
Summary
Performs unsupervised classification on a series of input raster bands using the Iso Cluster and Maximum Likelihood Classification tools.
Usage
This tool combines the functionalities of the Iso Cluster and Maximum Likelihood Classification tools. It outputs a classified raster. It optionally outputs a signature file.
When a multiband raster is specified as one of the Input raster bands (
in_raster_bandsin Python), all the bands will be used.To process a selection of bands from a multiband raster, you can first create a new raster dataset composed of those particular bands with the Composite Bands tool, and use the result in the list of the Input raster bands (
in_raster_bandsin Python).The resulting signature file from this tool can be used as the input for another classification tool, such as Maximum Likelihood Classification, for greater control over the classification parameters.
The minimum valid value for the number of classes is two. There is no maximum number of clusters. In general, more clusters require more iterations.
To provide the sufficient statistics necessary to generate a signature file for a future classification, each cluster should contain enough cells to accurately represent the cluster. The value entered for the minimum class size should be approximately 10 times larger than the number of layers in the input raster bands.
The value entered for the sample interval indicates one cell out of every n-by-n block of cells is used in the cluster calculations.
You shouldn't merge or remove classes or change any of the statistics of the ASCII signature file.
Generally, the more cells contained in the extent of the intersection of the input bands, the larger the values for minimum class size and sample interval should be specified. Values entered for the sample interval should be small enough that the smallest desirable categories existing in the input data will be appropriately sampled.
The class ID values on the output signature file start at one and sequentially increase to the number of input classes. The assignment of the class numbers is arbitrary.
The output signature file's name must have a
.gsgextension.Better results will be obtained if all input bands have the same data ranges. If the bands have vastly different data ranges, the data ranges can be transformed to the same range using Map Algebra to perform the equation.
where: *Z* is the output raster with new data ranges. *X* is the input raster. *oldmin* is the minimum value of the input raster. *oldmax* is the maximum value of the input raster. *newmin* is the desired minimum value for the output raster. *newmax* is the desired maximum value for the output raster.See Analysis environments and Spatial Analyst for additional details on the geoprocessing environments that apply to this tool.
Parameters
| Label | Explanation | Data type |
Input raster bands |
The input raster bands. They can be integer or floating point type. |
Raster Layer; Mosaic Layer |
Number of classes |
Number of classes into which to group the cells. |
Long |
Minimum class size (Optional) |
Minimum number of cells in a valid class. The default is 20. |
Long |
Sample interval (Optional) |
The interval to be used for sampling. The default is 10. |
Long |
Output signature file (Optional) |
The output signature file. A |
File |
Return value
Output classified raster |
The output classified raster. |
Raster |
Environments
Auto Commit, Cell Size, Cell Size Projection Method, Compression, Current Workspace, Extent, Geographic Transformations, Mask, Output CONFIG Keyword, Output Coordinate System, Scratch Workspace, Snap Raster, Tile Size
Licensing information
- Basic: Requires Spatial Analyst
- Standard: Requires Spatial Analyst
- Advanced: Requires Spatial Analyst
