Multiscale Surface Difference (Spatial Analyst Tools)
Summary
Calculates the maximum difference from the mean elevation across a range of spatial scales.
Learn more about how Multiscale Surface Difference works.
Usage
  • The maximum difference from the mean elevation is calculated across scales. These scales are the neighborhood distance value used for calculation (the distance from the target cell center, creating a square of cells around the target cell). For example, a scale of two cells is a 5 by 5 cell neighborhood.
  • For each scale, the mean elevation is found, and the difference between the center cell's value and that scale's mean elevation is found. The difference is retained for comparison with values of different scales.
  • The Input Surface Raster (in_raster in Python) parameter value can be any type of surface raster.
  • The Output Difference Raster (out_difference_raster in Python) parameter is the primary output. This is a raster containing the maximum difference from the mean elevation across a range of spatial scales.
  • The Output Scale Raster (out_scale_raster in Python) parameter provides more information about the primary output. It contains the scale at which the maximum difference from the mean elevation was found for each cell. The scale is the neighborhood distance value, which is the distance from the target cell center, creating a square of cells around the target cell.
  • Imperial unit options for the Distance Units parameter (distance_units in Python) are the international versions of the units. US Survey imperial units are not currently supported. If the map unit of the spatial reference for the Input Surface Raster value is US Survey, Cells will be the default value used for this parameter.
  • The Minimum Neighborhood Distance (min_scale in Python) and Maximum Neighborhood Distance (max_scale in Python) parameters define the minimum and maximum neighborhood sizes, or scales, that the difference will be calculated for. These values represent the smallest and largest distance from the target cell. For example, a value of 1 creates a 3 by 3 cell neighborhood, and a value of 2 creates a 5 by 5 cell neighborhood.
    These values cannot be less than the input raster cell size or 1 cell.
    The Minimum Neighborhood Distance parameter value must be less than or equal to the Maximum Neighborhood Distance parameter value.
  • The Distance Increment (increment in Python) parameter is the increase in neighborhood distance between scales.
    This parameter value cannot be less than the input raster cell size or 1 cell. The default value is the input raster cell size.
  • NoData cells in the Input Surface Raster value will be ignored and those cells will be assigned NoData in the Output Difference Raster and Output Scale Raster parameter values.
  • This tool can be GPU accelerated, which means that if a compatible graphics processing unit (GPU) is available on your system, it will be used to enhance the performance of the tool. Use the Target device for analysis parameter (analysis_target_device in Python) to control whether the GPU or CPU will be used to run the tool.
    See GPU processing with Spatial Analyst for details on compatible GPUs, configuring and working with GPU devices, as well as troubleshooting tips.
  • This tool supports parallel processing. If your computer has multiple processors or processors with multiple cores, better performance may be achieved, particularly on larger datasets. The Parallel processing with Spatial Analyst help topic includes details about this capability and how to configure it.
    By default, this tool will use 50 percent of the available cores. You can control the number of cores the tool uses with the Parallel processing factor environment.
  • When the output raster format is .crf, this tool supports the Pyramid raster storage environment. Pyramids will be created in the output by default. For any other output format, this environment is not supported, and pyramids will not be created.
  • See Analysis environments and Spatial Analyst for additional details on the geoprocessing environments that apply to this tool.
Parameters
Label Explanation Data type
The input surface raster.
Raster Layer
Output Scale Raster
(Optional)
The output raster containing the scale at which the most extreme difference was found for each cell. Scales are represented as their neighborhood distance values.
It will be floating-point type.
Raster Dataset
Distance Units
(Optional)
Specifies the distance unit that will be used for the Minimum Neighborhood Distance, Maximum Neighborhood Distance, and Distance Increment parameters.
Distance will be measured in the number of cells or specified unit. The default is the map unit of the spatial reference for the Input Surface Raster value.
  • Cells—The distance unit will be cells.
  • Meters—The distance unit will be meters.
  • Centimeters—The distance unit will be centimeters.
  • Kilometers—The distance unit will be kilometers.
  • Inches—The distance unit will be international inches.
  • Feet—The distance unit will be international feet.
  • Yard—The distance unit will be international yards.
  • Miles—The distance unit will be international miles.
String
(Optional)
The distance that defines the minimum neighborhood scale that elevation difference will be calculated for. This is the distance from the target cell center, creating a square of cells around the target cell.
This value must be less than or equal to the Maximum Neighborhood Distance parameter value and greater than or equal to the input raster cell size or one cell.
The default value is four times the cell size of the Input Surface Raster parameter value, resulting in a 9-by-9 cell neighborhood.
Double
(Optional)
The distance that defines the maximum neighborhood scale that elevation difference will be calculated for. This is the distance from the target cell center, creating a square of cells around the target cell.
This value must be greater than or equal to the Minimum Neighborhood Distance parameter value and the input raster cell size or one cell.
The default value is 13 times the cell size of the Input Surface Raster parameter value, resulting in a 27-by-27 cell neighborhood.
Double
Distance Increment
(Optional)
The increase in neighborhood distance between scales.
This parameter value cannot be less than the Input Surface Raster cell size or 1 cell.
The default value is the cell size of the Input Surface Raster parameter value.
Double
Target Device for Analysis
(Optional)
Specifies the device that will be used to perform the calculation.
  • GPU then CPU—If a compatible GPU is found, it will be used to perform the calculation; otherwise, the CPU will be used. This is the default.
  • CPU only—The calculation will only be performed on the CPU.
  • GPU only—The calculation will only be performed on the GPU.
String
Return value
The output raster containing the maximum difference from the mean elevation for each cell.
Raster
Environments
Auto Commit, Cell Size, Cell Size Projection Method, Current Workspace, Extent, Geographic Transformations, GPU ID, Mask, Output CONFIG Keyword, Output Coordinate System, Parallel Processing Factor, Processor Type, Pyramid, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires Spatial Analyst
  • Standard: Requires Spatial Analyst
  • Advanced: Requires Spatial Analyst
