Principal Components (Spatial Analyst Tools)
Summary
Performs Principal Component Analysis (PCA) on a set of raster bands and generates a single multiband raster as output.
Usage
The value specified for the number of principal components determines the number of principal component bands in the output multiband raster. The number must not be larger than the total number of raster bands in the input.
When a multiband raster is specified as one of the Input Raster Bands (
in_raster_bandsin Python), all the bands will be used.To process a selection of bands from a multiband raster, you can first create a new raster dataset composed of those particular bands with the Composite Bands tool, and use the result in the list of the Input Raster Bands (
in_raster_bandsin Python).The raster bands must have a common intersection. If there are none, an error occurs and no output is created.
The percent variance identifies the amount of the variance each eigenvalue captures. This can be useful to help interpret the results of PCA. If a few eigenvalues (each corresponding to bands in the output raster) capture the majority of the variance, it may be adequate to use this subset of bands in a subsequent analysis, since they may capture the majority of the interactions within the original multiband dataset.
When determining the percent variance each eigenvalue captures, the sum of eigenvalues is entered into the following formula: (eigenvalue * 100)/Sum. The first eigenvalue (and its associated band) captures the greatest variance, and the subsequent eigenvalues capture sequentially lesser variance. The accumulative percent of variance is a sequential sum of the variance each eigenvalue captures.
See Analysis environments and Spatial Analyst for additional details on the geoprocessing environments that apply to this tool.
Parameters
| Label | Explanation | Data type |
Input Raster Bands |
The input raster bands. They can be integer or floating point type. |
Raster Layer |
Number of Principal Components (Optional) |
Number of principal components. The number must be greater than zero and less than or equal to the total number of input raster bands. The default is the total number of rasters in the input. |
Long |
Output Data File (Optional) |
Output ASCII data file storing principal component parameters. The output data file records the correlation and covariance matrices, the eigenvalues and eigenvectors, the percent variance each eigenvalue captures, and the accumulative variance described by the eigenvalues. The extension for the output file can be |
File |
Return value
Output Multiband Raster |
The output multiband raster dataset. If all of the input bands are integer type, the output raster bands will be integer. If any of the input bands are floating point, the output will be floating point. If the output is an Esri Grid raster, the name must have less than 10 characters. |
Raster |
Environments
Auto Commit, Cell Size, Cell Size Projection Method, Compression, Current Workspace, Extent, Geographic Transformations, Mask, Output CONFIG Keyword, Output Coordinate System, Scratch Workspace, Snap Raster, Tile Size
Licensing information
- Basic: Requires Spatial Analyst
- Standard: Requires Spatial Analyst
- Advanced: Requires Spatial Analyst
