Surface Area Ratio (Spatial Analyst Tools)
Summary
Calculates a surface area to planar area ratio for each cell of a raster surface.
Learn more about how Surface Area Ratio works
Usage
  • The cell values of the output raster represent the ratio between the 3D surface area and the 2D planar area at each cell location. This ratio is a rugosity index that can be used to model the seafloor or land surface structural complexity.
  • The Input Surface Raster parameter value can be bathymetry or topographic digital elevation model data.
  • The Planar Area Type parameter supports two types of 2D planar area, horizontal and arc-chord.
    When the Horizontal option is selected, the tool will use the cell area projected on the horizontal plane as the 2D planar area. When the Arc-Chord option is selected, the 2D planar area will be the cell area projected on the plane of best fit calculated in a 3 by 3 cell neighborhood. In this case, the output surface area ratio value will be decoupled from the effect of local slope, which is known as an arc-chord rugosity index (Du Preez, 2015).
  • If the height value of the input surface raster is in a different unit than the XY unit, it will be internally converted to the XY unit before it is used. For the optional Output Surface Area Raster parameter value, the units are the XY unit squared. For example, if the XY unit of the input surface raster is meters, the area unit of the output surface area raster values will be square meters.
  • Specifying the surface Z Unit parameter value ensures the proper computation of the surface area.
    If a z unit is available in the vertical coordinate system of the input raster, it will be applied automatically. It is recommended that you define a z unit for the input raster if it is missing. You can use the Define Projection tool to specify a z unit. If it is undefined, meter will be used by default.
  • When the output raster format is .crf, this tool supports the Pyramid raster storage environment. Pyramids will be created in the output by default. For any other output format, this environment is not supported, and pyramids will not be created.
  • See Analysis environments and Spatial Analyst for additional details on the geoprocessing environments that apply to this tool.
Parameters
Label Explanation Data type
The input surface raster.
Raster Layer
(Optional)
The output surface area raster.
This output raster stores the 3D surface area at each cell location.
Raster Dataset
Z Unit
(Optional)
Specifies the linear unit that will be used for vertical z-values.
It is defined by a vertical coordinate system if it exists. If no vertical coordinate system exists, define the z-unit using the unit list to ensure correct geodesic computation. The default is meter.
  • Inch—The linear unit will be inches.
  • Foot—The linear unit will be feet.
  • US Foot—The linear unit will be US survey feet.
  • Yard—The linear unit will be yards.
  • US Mile—The linear unit will be US survey miles.
  • Nautical mile—The linear unit will be nautical miles.
  • Millimeter—The linear unit will be millimeters.
  • Centimeter—The linear unit will be centimeters.
  • Meter—The linear unit will be meters.
  • Kilometer—The linear unit will be kilometers.
  • Decimeter—The linear unit will be decimeters.
String
Planar Area Type
(Optional)
Specifies the type of 2D planar area that will be used in surface area ratio calculation.
  • Horizontal—The 2D planar area will be the cell area projected onto a horizontal plane.
  • Arc-Chord—The 2D planar area will be the cell area projected onto the plane of best fit in a 3 by 3 cell neighborhood. This planar area type is used to calculate the arc-chord rugosity index. This is the default.
String
Return value
Output Raster
The output surface area ratio raster.
Raster
Environments
Auto Commit, Cell Size, Cell Size Projection Method, Compression, Current Workspace, Extent, Geographic Transformations, Mask, Output CONFIG Keyword, Output Coordinate System, Parallel Processing Factor, Pyramid, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires Spatial Analyst
  • Standard: Requires Spatial Analyst
  • Advanced: Requires Spatial Analyst
References
Du Preez, C. "A new arc-chord ratio (ACR) rugosity index for quantifying three-dimensional landscape structural complexity". Landscape Ecology, 2015, 30, 181-192.
