000243: The units value is either invalid or not supported.
This error may occur for the following reasons:
When working with the Raster to NetCDF tool, the specified unit is either invalid or not supported by the UDUNITS library.
When working with the Tabulate Intersection tool, review the Output Units parameter value. When the tool is tabulating area, the parameter value must be areal units (for example Square Kilometers), and when the tool is tabulating length, the parameter value must be linear units (for example Kilometers).
When working with the Generate Tessellation tool, converting areal units to a geographic coordinate system will produce incorrect or undesirable results.
Solution
Do one of the following:
Specify a unit supported by the UDUNITS library.
Specify a different unit value.
Do not use a geographic coordinate system extent with anything other than Unknown units. Alternatively, specify an appropriate coordinate system for areal calculation.
